2d images plotted with isotropic scales
forborto
Sorry if this was covered before, but I didn't figure out how to search!
In IDL, a keyword, '/isotropic', can be used to force the x and y scales to be the same, while plotting. That is, if you are plotting over a range of 5 cm in the x-direction and 5 m in the y-direction, the plot will be forced to an elongate narrow rectangle.
Is there a way to do this in Igor? When I have plots where the axes are both real dimensions, I like to have this feature. The only way I've done it in Igor is by sizing the window by eye, but that's not ideal...
Thanks
Use n=1 to get:
This is accessible in the Modify Graph... dialog (see the Graph menu).
For more info, enter this command:
To search the help, choose "Search Igor Files" from the Help menu, make sure "Help Files" and "In the Igor Pro Folder" are checked, and enter something to search for.
Jim Prouty
January 19, 2010 at 07:03 pm - Permalink
Works great. Thanks so much. I've used Igor on and off for 7 years and never realized that feature!
January 29, 2010 at 07:03 pm - Permalink
