Index out of range
sjr51
I am getting the error that "index is out of range" but I can't see what the problem is. My procedure is below. It takes a 2D wave corresponding to xy coordinates and rotates them about the origin. To do this it takes the last coordinate, calculates the angle to move this point to lie at y=0 and X>0, i.e. due east from the origin. Then goes through each row in the wave and rotates each coordinate by this angle.
I added a print statement for debugging. It sails through my wavelist and calculates the angle for all waves. It then throws the index out of range error (the wave in question is the first one in my wavelist). The bizarre thing is that my graph gets updated with maybe half of the waves rotated correctly. I checked numpnts for the wave that throws the error and what the last point is, both are correct.
Any help would be appreciated. If there is a better flow control method than a for-endfor within a for-endfor, it would be great if someone can tell me what it is. Does this explain why the graph gets partially updated?
Thanks
sjr51
Function Rotator(wavenames) //rotates a set of 2D coordinates about the origin
String wavenames
Variable theta, xprime, yprime, xcd, ycd
variable i=0
Variable j=0 // i will count through the waves, j will be row index
Variable ABx, CDx, ABy, CDy
For (i = 0; i < ItemsInList(wavenames); i += 1)
String name = StringFromList(i,wavenames)
Wave/z w1= $name
variable last = NumPnts(w1)/2
ABx=1 //calculate theta. ABx and ABy are set at 1,0. This will give a 1 unit long line at 90°
CDx=w1[last][0]
ABy=0
CDy=w1[last][1]
theta=acos(((ABx*CDx)+(ABy*CDy))/(sqrt((ABx^2)+(ABy^2))*sqrt((CDx^2)+(CDy^2)))) //answer in radians
print name, " is ",theta
For (j = 0; j < last; j+=1)
xcd = w1[j][0]
ycd = w1[j][1]
xprime = (xcd*(cos(theta)))-(ycd*(sin(theta)))
yprime = (xcd*(sin(theta)))+(ycd*(cos(theta)))
w1[j][0] = xprime
w1[j][1] = yprime
String wavenames
variable i=0
Wave/z w1= $name
CDx=w1[last][0]
ABy=0
CDy=w1[last][1]
xcd = w1[j][0]
ycd = w1[j][1]
w1[j][0] = xprime
w1[j][1] = yprime
NumPnts(w1)/2
might be problematic. What if the wave has 11 points (=> NumPnts/2 = 5.5 ~ 6)?Edit: Ok, that was maybe not very helpful since you seem to have checked various things already. There are however some statements in your post which are contradicting. For example, how can the first wave in your list be the problem, when the data is handled correctly until a certain point? Anyway, it might help if you could post a simple example experiment with some data where the error is present.
July 25, 2014 at 04:42 am - Permalink
The waves are 2D sets of coordinates so I *think* that last = Numpnts(w1)2 will be OK, because Numpnts should be 2* row number (I wasn't sure how to do this). I'm sure you are right about last or j being the problem.
I have posted a simplified version of the experiment. When you execute this command on Graph0:
It replicates the problem that I described for the full experiment. Error for the first wave in the wavelist, printing all angles and rotating some of them in the graph.
Again - any help would be appreciated!
Steve
July 25, 2014 at 05:06 am - Permalink
By calculating
NumPnts(w1)/2
you get the full number of points in the row dimension of your wave. So for so good. But since counting starts from zero, you have the number of points minus one as the last index. Using this directly as assignment will lead to the error.Just change the following and the error will go away:
CDx=w1[last-1][0]
ABy=0
CDy=w1[last-1][1]
July 25, 2014 at 05:28 am - Permalink
July 25, 2014 at 06:04 am - Permalink
July 25, 2014 at 08:36 am - Permalink
The debugger regularly saves my life (or at least my sanity).
July 25, 2014 at 09:35 am - Permalink
#pragma rtGlobals=2
which did not generate this error. Attempting to draw a circle at a non-existing point no longer caused a problem.
However, you should be clear whether your particular range error is harmless before using this fix.
July 26, 2014 at 09:06 am - Permalink
July 26, 2014 at 11:46 am - Permalink
