Find all possible distances between two sets of xy coords
sjr51
Currently I do this:
•make/o/n=(10,2) aa=p*(q+2) // make some integer coords for illustration
•make/o/n=(20,2) bb
•bb[][0] += 3
•bb[][1] += 4 // second set is 5 units away
•make/o/n=(dimsize(aa,0),dimsize(bb,0),2) cc // to contain the difference between each point, x in layer 0, y in layer 1
•matrixtranspose bb
•cc[][][0] = aa[p][0] - bb[0][p]
•cc[][][1] = aa[p][1] - bb[1][p] // subtract each point in bb from each point in aa
•matrixop/o dd = cc * cc
•matrixop/o ee = sumbeams(dd)
•matrixop/o ff = sqrt(ee) // 2D wave of all distances
•make/o/n=(20,2) bb
•bb[][0] += 3
•matrixtranspose bb
I can't do the last three MatrixOps as a compound expression because of sumbeams.
Is there a simple command to do this? Or any other way to simplify these steps? Any input would be appreciated.
Elsewhere in my code I turn these coordinate sets into image masks using
ImageBoundaryToMask
and I looked at image operations to find the distances but couldn't figure out a good way to do this.
Otherwise, here is my way of using matrixop. I broke it down to individual instructions and it is past midnight here so you may want to check it twice.
// make sample data
make/O/n=10 ax=p,ay=p
make/o/n=8 bx=10*p,by=10*p
// create matrices that are 10x8:
Matrixop/o/free matAx=colRepeat(ax,8)
Matrixop/o/free matAy=colRepeat(ay,8)
Matrixop/o/free matBx=rowRepeat(bx,10)
Matrixop/o/free matBy=rowRepeat(by,10)
Matrixop/o/free distanceX=matAx-matBx
Matrixop/o/free distanceY=matAy-matBy
MatrixOP/o distances=sqrt(distanceX*distanceX+distanceY*distanceY)
Now you have to pick the relevant data (array) out of the full matrix. It is not the most efficient but it is probably worth trying.
I hope this helps,
February 28, 2018 at 12:31 am - Permalink
I'm not looking at clusters right now. I actually just want to find the closest distance between the two sets of points.
February 28, 2018 at 04:35 am - Permalink
Look at FPClustering. I think that if you set it correctly you could get the closest distance.
February 28, 2018 at 08:33 am - Permalink
// make sample data
make/O/n=10 ax=p+2.5,ay=p+3.75
ImageStats distances
return V_min
ImageStats can also provide the matrix location of the minimum distance at V_minColLoc and V_minRowLoc. You will have to figure out whether or how to search for other equal minimum distances in your data set.
February 28, 2018 at 09:08 am - Permalink
FPClustering can't work here because it normalizes each column of the position data. It is also difficult to make it output distances that are not clustered. I will look into adding such an option for IP8.
February 28, 2018 at 10:42 am - Permalink
// Make sample data using two-column waves. For higher dimensions use cols=nDims.
make/O/n=(10,2) aa
aa[][0]=p+2.5
aa[][1]=p+3.75
make/o/n=(8,2) bb
bb[][0]=10*p
bb[][1]=10*p
// Combine the two distance groups into a single positions wave:
Concatenate/NP=0 {aa,bb}, positions
FPClustering/DSO positions // Requires IP8
Wave M_DistanceMap
// the output M_DistanceMap is an upper triangular matrix containing the distances.
// since you do not care about the distances between positions internal to {aa} or {bb}
// extract the relevant matrix:
Variable colStart=DimSize(aa,0)
Variable colEnd=colStart+DimSize(bb,0)-1
Variable rowsStart=0
Variable rowsEnd=colStart-1
// you can extract the relevant part by:
MatrixOP/o/FREE myDistance=subRange(M_DistanceMap,rowsStart,rowsEnd,colStart,colEnd)
return WaveMin(myDistance)
February 28, 2018 at 11:36 am - Permalink
@s.r.chinn thank you for the input. I am using exactly this in my code right now.
February 28, 2018 at 12:24 pm - Permalink
