[XOP] C macros for printing to the history
One can also move the variable definition char buf[] out of the macro and use a global buffer instead (single threaded code only).
<br />
#define ARRAY_SIZE 1024<br />
// Accepts multipe arguments like printf and prints them to the history<br />
// Custom prefixes can be also inserted, see the DEBUGPRINT macro<br />
// Copies only ARRAY_SIZE-2 characters in _snprintf, because we want to have space for the terminating \0 (1) and for the CR (1)<br />
// Checking the return value of _snprintf is not done on purpose, we just always append a \0 to be safe<br />
// @param A prints only if A evaluates to true<br />
// @param B uses silent printing (does not mark the experiment as changed) if true<br />
#define PRINT_TO_HISTORY(A,B,...) \<br />
if (RunningInMainThread() && A) \<br />
{ \<br />
char buf[ARRAY_SIZE]; \<br />
_snprintf(buf,ARRAY_SIZE-2, __VA_ARGS__); \<br />
buf[ARRAY_SIZE-2] = '\0'; \<br />
strcat(buf,CR_STR); \<br />
if (!B) \<br />
{ \<br />
XOPNotice(buf); \<br />
} \<br />
else \<br />
{ \<br />
XOPNotice2(buf,0); \<br />
} \<br />
}<br />
<br />
// debuggingEnabled is a global boolean variable or similar which turns debug output on/off<br />
<br />
// Convenience wrapper using silent debug print<br />
#define DEBUGPRINT_SILENT(...) \<br />
PRINT_TO_HISTORY(debuggingEnabled,true,"DEBUG: "__VA_ARGS__)<br />
<br />
// Convenience wrapper using debug print<br />
#define DEBUGPRINT(...) \<br />
PRINT_TO_HISTORY(debuggingEnabled,false,"DEBUG: "__VA_ARGS__)<br />
<br />
// Convenience wrapper for printing<br />
#define HISTPRINT(...) \<br />
PRINT_TO_HISTORY(true,false,__VA_ARGS__)<br />
<br />
// Convenience wrapper for silent printing<br />
#define HISTPRINT_SILENT(...) \<br />
PRINT_TO_HISTORY(true,true,__VA_ARGS__)<br />
Usage:
<br />
int ret = MDSetWaveScaling(m_waveHandle,dimension,sfAPtr,sfBPtr);<br />
if(ret != 0){<br />
HISTPRINT("MDSetWaveScaling returned error %d",ret);<br />
}<br />
// [...]<br />
DEBUGPRINT("traceUpRawBrickletIndex=%d,rawBrickletSize=%d",rawIndex,rawBrickletSize);<br />
// [...]<br />
DEBUGPRINT("numPointsRootAxis=%d",numPointsRootAxis);<br />
