Working With Binary String Data Examples
These example functions demonstrate some uses for StringToUnsignedByteWave and WaveDataToString, two built-in functions that were introduced in Igor Pro 9.00B08 (released July 27, 2021). If you would like access to Igor Pro 9 Beta, please submit the sign up form.
For more information, execute the following command:
DisplayHelpTopic "Working With Binary String Data"
Calculating an amino acid histogram:
// Calculate a histogram of the amino acids found // in the human SARS-CoV-2 spike protein. Function covidSpikeAminoAcidHistogram() String url = "https://eutils.ncbi.nlm.nih.gov/entrez/eutils/efetch.fcgi?db=protein&id=QWK65230&rettype=fasta&retmode=text" URLRequest url=url if (V_responseCode != 200) print "Failed to successfully download protein sequence." return 0 endif String response = S_serverResponse // The first line in the response is a description of the // sequence. The sequence starts after the first line feed character. Variable sequenceStart = strsearch(response, "\n", 0) if (sequenceStart <= 0) print "Could not find start of sequence." return 0 endif String sequence = response[sequenceStart+1, inf] // Remove any line endings in the sequence sequence = ReplaceString("\n", sequence, "") sequence = TrimString(sequence) // Convert the sequence into a byte wave WAVE/B/U seqWave = StringToUnsignedByteWave(sequence) // Calculate the histogram with 26 bins (one for each letter). // Start the bins at the numeric value 65, which corresponds to "A". Histogram/C/B={char2num("A"),1,26}/DEST=seqHistWave seqWave // Create a text wave that contains the amino acid abbreviations. Make/O/N=26/T aminoAcidLabels aminoAcidLabels = num2char(char2num("A") + p) // Some letters do not correspond to an actual amino acid. So // delete those points from both waves. DeletePoints char2num("Z") - char2num("A"), 1, seqHistWave, aminoAcidLabels DeletePoints char2num("X") - char2num("A"), 1, seqHistWave, aminoAcidLabels // U is Selenocysteine. It is rare. // DeletePoints char2num("U") - char2num("A"), 1, seqHistWave, aminoAcidLabels // O is pyrrolysine. It is rare. // DeletePoints char2num("O") - char2num("A"), 1, seqHistWave, aminoAcidLabels DeletePoints char2num("J") - char2num("A"), 1, seqHistWave, aminoAcidLabels DeletePoints char2num("B") - char2num("A"), 1, seqHistWave, aminoAcidLabels // Sort the histogram wave to increasing size. Also sort // the amino acid labels wave in the same order. Sort seqHistWave, seqHistWave, aminoAcidLabels // Display the histogram. Display seqHistWave vs aminoAcidLabels End
Here is the graph produced by executing the function:
ROT13 Encoding:
ROT13 is a simple cipher that replaces a letter with the 13th letter after it.
// Returns a ROT13 encoded string. // See https://en.wikipedia.org/wiki/ROT13 for more information. Function/S ROT13(String inStr) if (!strlen(inStr) > 0) // null or empty string return inStr endif Variable la = char2num("a") // 97 Variable lz = char2num("z") // 122 Variable bA = char2num("A") // 65 Variable bZ = char2num("Z") // 90 // Get the bytes WAVE/B/U bytes = StringToUnsignedByteWave(inStr) // encode uppercase letters bytes = (bytes[p] >= bA && bytes[p] <= bZ) ? mod(bytes[p] - bA + 13, 26) + bA : bytes[p] // encode lowercase letters bytes = (bytes[p] >= lA && bytes[p] <= lZ) ? mod(bytes[p] - lA + 13, 26) + lA : bytes[p] // convert back to a string String outStr = WaveDataToString(bytes) return outStr End
•print rot13("AbC+z") NoP+m •print rot13("NoP+m") AbC+z
Generating Random Text:
// Returns a random printable ascii character. // "Printable" characters include the space, tab, line feed, // and carriage return character. ThreadSafe Function RandomPrintableChar() Variable c do c = trunc(abs(enoise(126))) if ((c >= 32 && c <= 126) || c == 9 || c == 10 || c == 13) break endif while (1) return c End // Generates length bytes of random ASCII text. Function/S RandomPrintableText(Variable length) Make/FREE/B/U/N=(length) chars MultiThread chars = RandomPrintableChar() String theText = WaveDataToString(chars) return theText End
•print RandomPrintableText(10) YI2XcCsPR9 •print RandomPrintableText(10) 18'Gf[C\O%
Remove Non-printable Characters From a String
An example of how to remove non-printable characters from a string is given in a separate code snippet.
