using Windows command line, e.g. to find files on disk
ExecuteScriptText
, but the manual says it cannot read results back. Here's a little snippet to do just that. You can use this to find directories in the Windows path variable, or to find files (with wild cards) on a disk drive:•print ExecuteWinCmd("echo hello, world!") hello, world! •print SearchWindowsPath("miktex") C:\Programme\MiKTeX 2.7\miktex\bin; •print FindFilesOnDisk("c", "latex.exe") looking for latex.exe on drive c: - please stand by, this may take a long time! C:\Programme\MiKTeX 2.7\miktex\bin\latex.exe;
Here's the code you need to paste in your Procedure window:
function/S ExecuteWinCmd(command) string command string IPUFpath = SpecialDirPath("Igor Pro User Files",0,1,0) // guaranteed writeable path in IP6 string batchFileName = "ExecuteWinCmd.bat", outputFileName = "ExecuteWinCmd.out" string outputLine, result = "" variable refNum NewPath/O/Q IgorProUserFiles, IPUFpath Open/P=IgorProUserFiles refNum as batchFileName // overwrites previous batchfile fprintf refNum,"cmd/c \"%s > \"%s%s\"\"\r", command, IPUFpath, outputFileName Close refNum ExecuteScriptText/B "\"" + IPUFpath + "\\" + batchFileName + "\"" Open/P=IgorProUserFiles/R refNum as outputFileName do FReadLine refNum, outputLine if( strlen(outputLine) == 0 ) break endif result += outputLine while( 1 ) Close refNum return result end function/S SearchWindowsPath(str) string str return ListMatch(ExecuteWinCmd("path"),"*"+str+"*") end function/S FindFilesOnDisk(driveName, fileName) string driveName, fileName string fileNotFoundString = "_file not found_" // change this to "", if you prefer an empty string // allow user to specify "c" or "C:", or even "" (converted to "C:") as the driveName switch( strlen(driveName) ) case 0: driveName = "c" // fall through case 1: driveName += ":" case 2: break default: Abort "illegal drive specification" endswitch // attrib/s is the fastest way to find a file with a given name (with wild cards) anywhere on a disk // but it can still take a long time, especially with large hard disks! print "looking for "+fileName+" on drive "+driveName+" - please stand by, this may take a long time!" // here we go... this command returns only when Windows has finished with it string found = ExecuteWinCmd("attrib /s "+driveName+"\\"+fileName) // convert line break characters to ";" to make the answer an Igor list found = ReplaceString("\r", found, ";") string str, result = "" variable n, nmax = ItemsInList(found) - 1 // if we get only one item, then it's possible that the file was not found // attrib/s then returns something like "file C:\bla.bla not found" // unfortunately, that message is in the local language of the OS ! if( nmax == 0 ) str = found[0, strsearch(found, driveName, 0, 2) - 1] // if the characters before the file name ... if( strsearch(str, UpperStr(str), 0) < 0 ) // ... contain lower case characters ... return fileNotFoundString // ... we assume the file was not found endif endif // the file was probably found, maybe even more than once // attrib/s then returns something like "A HR C:\jack\data\bla.bla" // the length of the attribute list seems unpredictable, but it's all uppercase for( n = nmax; n >= 0; n -= 1 ) str = StringFromList(n, found) // for each item str = str[strsearch(str, driveName, 0, 2), strlen(str)-1] // excise file path result = AddListItem(str, result) // add to result list endfor return result end
I would be happy about feedback from testers, especially of the
FindFilesOnDisk
routine since it contains some assumptions about international Windows systems (see code documentation).
