Stocks High Low Close Open Trace
Tracking the daily price of stocks uses a "High/Low/Close/Open" graph, which shows all 4 daily prices on one day. See the attached image for an example graph.
This code snippet adds an "Append High Low close Open Trace" item to Igor's Graph menu, and also two submenus for controlling trace thickness and color. The submenus are warranted because the trace's color and thickness are controlled by multiple trace settings, and it makes it easier to ensure they're all set to the same values.
Igor 6.2's custom markers feature makes this trace possible: it draws the open and close markers as, essentially, half-markers, pointing to the left (for the opening price) or the right (for the closing price).
The snippet is not very sophisticated: it creates a wave in the current data folder that combines the high and low price waves into one trace.
Input data is a set of 5 equal length waves: {high price, low price, close price, open price} vs date
The output adds a 6th high/low wave graphed instead of the individual high price and low price wave.
#pragma rtGlobals=2     // Use modern global access method.
#pragma IgorVersion=6.2 // for markerHook
Menu "Graph", dynamic
    Submenu "High Low Close Open Trace"
        "Append High Low Close Open Trace", mAppendHighLowCloseOpen()
        Submenu "Line Sizes"
            HighLowCloseOpenLineSizesMenu(), /Q, DoHighLowCloseOpenLineSize()
        Submenu "Color"
            HighLowCloseOpenColorMenu(),/Q, DoHighLowCloseOpenColor()
Function OpenCloseMarkerProc(s)
    STRUCT WMMarkerHookStruct &s
    if( s.marker > 3 )
    Variable overhang= s.penThick/2
    Variable size= s.size - overhang
    if( s.marker == 0 )         // open
        DrawLine s.x-size, s.y, s.x+overhang , s.y
    elseif( s.marker == 1 )     // close
        DrawLine s.x-overhang, s.y, s.x+size, s.y
    return 1
Constant kOpenMarker =100
Constant kCloseMarker =101
StrConstant ksHighLowCloseOpenUserDataName="WMHighLowCloseOpenData"
static Function HaveHighLowCloseOpen(graphName)
    String graphName
    if( strlen(graphName) == 0 )
    DoWindow $graphName
    if( V_Flag == 0 )
    String traces= TraceNameList(graphName, ";", 1)
    Variable i, n= ItemsInList(traces)
    for(i=0; i<n; i+=1 )
        String traceName= StringFromList(i,traces)
        String userData= GetUserData(graphName, traceName, ksHighLowCloseOpenUserDataName)
        strswitch(userData)
            case "open":
            case "close":
            case "high/low":
                return 1    // have at least one open/close/high/low trace
                break
        endswitch
Function/S HighLowCloseOpenColorMenu()
    String colorMenu= "*COLORPOP*"
    if( !HaveHighLowCloseOpen(WinName(0,1)) )
        colorMenu=  "\M1:(:"+colorMenu
    return colorMenu
Function/S HighLowCloseOpenLineSizesMenu()
    String sizes="0.5;1;2;3;4;5;6;7;8;9;"
        Variable i, n= ItemsInList(sizes)
        String disabledSizes=""
            String size= StringFromList(i,sizes)
            disabledSizes +=  "\M1:(:"+size+";"
        sizes= disabledSizes
    return sizes
Function DoHighLowCloseOpenLineSize()
    GetLastUserMenuInfo
    Variable lineSize= str2num(S_Value)
    SetHighLowCloseOpenLineSize(lineSize)
Function DoHighLowCloseOpenColor()
    GetLastUserMenuInfo
    SetHighLowCloseOpenColor(V_Red, V_Green, V_Blue)
Function SetHighLowCloseOpenColor(red, green, blue)
    Variable red, green, blue
    // find all the traces related to high-low-open-close and change the line size or marker stroke size.
    String graphName= WinName(0,1)
        Beep
        strswitch(userData)
            case "open":
            case "close":
            case "high/low":
                ModifyGraph/W=$graphName rgb($traceName)=(red, green, blue)
                break
        endswitch
Function SetHighLowCloseOpenLineSize(lineSize)
    Variable lineSize
        Beep
        strswitch(userData)
            case "open":
            case "close":
                ModifyGraph/W=$graphName mrkThick($traceName)=lineSize, msize($traceName)=lineSize*3
                break
            case "high/low":
                ModifyGraph/W=$graphName lsize($traceName)=lineSize
                break
        endswitch
Proc mAppendHighLowCloseOpen(wHigh, wLow, wClose, wOpen, wDays)
    String wHigh, wLow, wClose, wOpen, wDays
    Prompt wHigh, "High Prices", popup, WaveList("*",";","DIMS:1")
    Prompt wLow, "Low Prices", popup, WaveList("*",";","DIMS:1")
    Prompt wClose, "Close Prices", popup, WaveList("*",";","DIMS:1")
    Prompt wOpen, "Open Prices", popup, WaveList("*",";","DIMS:1")
    Prompt wDays, "Days", popup, WaveList("*",";","DIMS:1")+";_none_;"  // can be string or numeric wave or _none_
    AppendHighLowCloseOpen($wHigh, $wLow, $wClose, $wOpen, $wDays)
Function AppendHighLowCloseOpen(wHigh, wLow, wClose,  wOpen,wDays)
    Wave wHigh, wLow, wOpen, wClose
    Wave/Z wDays
        DoAlert 0, "Make a graph, first!"
    String outName= CleanupName(NameOfWave(wHigh)[0,14]+"_"+NameOfWave(wLow)[0,14],1)
    if( !WaveExists(wDays) )
        Variable n= numpnts(wOpen)
        String daysName= CleanupName(outName[0,25]+"_days",1)
        Make/O/N=(n) $daysName= p+1 // 1-n
        WAVE wDays= $daysName
    SetWindow $graphName markerHook={OpenCloseMarkerProc,kOpenMarker,kCloseMarker}
    AppendToGraph/W=$graphName wOpen,wClose vs wDays
    String openTraceName= NameOfWave(wOpen)
    String closeTraceName= NameOfWave(wClose)
    ModifyGraph/W=$graphName mode($openTraceName)=3, mode($closeTraceName)=3
    ModifyGraph/W=$graphName marker($openTraceName)=kOpenMarker,marker($closeTraceName)=kCloseMarker
    ModifyGraph/W=$graphName mrkThick($openTraceName)=1,mrkThick($closeTraceName)=1
    //  Make this work: String userData= GetUserData(graphName, $openTraceName, ksHighLowCloseOpenUserDataName)
    ModifyGraph/W=$graphName userData($openTraceName)={$ksHighLowCloseOpenUserDataName, 0, "open"}
    ModifyGraph/W=$graphName userData($closeTraceName)={$ksHighLowCloseOpenUserDataName, 0, "close"}
    WAVE  wHighLow= fMakeHighLowWave(wHigh, wLow, outName)
    String dayOutName= CleanupName(NameOfWave(wDays)[0,14]+"_4HiLo",1)
    WAVE wHiLoDays= fMakeHighLowDays(wDays, dayOutName)
    AppendToGraph/W=$graphName wHighLow vs wHiLoDays
    ModifyGraph/W=$graphName mode($outName)=0
    ModifyGraph/W=$graphName userData($outName)={$ksHighLowCloseOpenUserDataName, 0, "high/low"}
Function/WAVE fMakeHighLowWave(wHigh, wLow, outName)
    Wave wHigh, wLow
    String outName
    Duplicate/O wHigh, $outName/WAVE=wout
    Variable n=numpnts(wHigh)
    Redimension/N=(3*numpnts(wHigh)) wout
    wout[0;3] = wHigh[p/3]      // interleave high first
    wout[1;3] = wLow[(p-1)/3]   // then low
    wout[2;3] = NaN             // then gap
    return wout
Function/WAVE fMakeHighLowDays(wDay, dayOutName)
    Wave wDay   // can be text or numeric wave
    String dayOutName
    Duplicate/O wDay, $dayOutName/WAVE=wout
    Variable n=numpnts(wDay)
    Redimension/N=(3*n) wout
    wout= wDay[trunc(p/3)]
    return wout
Window OpenCloseHighLowStyle() : GraphStyle
    PauseUpdate; Silent 1       // modifying window...
    ModifyGraph/Z mode[0]=3,mode[1]=3
    ModifyGraph/Z marker[0]=100,marker[1]=101
    ModifyGraph/Z lSize[2]=3
    ModifyGraph/Z rgb[0]=(1,16019,65535),rgb[1]=(1,16019,65535),rgb[2]=(1,16019,65535)
    ModifyGraph/Z msize[0]=9,msize[1]=9
    ModifyGraph/Z mrkThick[0]=3,mrkThick[1]=3
    ModifyGraph/Z grid(bottom)=1
    ModifyGraph/Z nticks(bottom)=10
    ModifyGraph/Z axOffset(bottom)=-1.66667
    ModifyGraph/Z tkLblRot(bottom)=90
    ModifyGraph/Z manTick(bottom)={3450384000,1,0,0,day},manMinor(bottom)={0,50}
    ModifyGraph/Z dateInfo(bottom)={0,0,0}
    Label/Z bottom " "
    SetWindow kwTopWin,markerHook={OpenCloseMarkerProc,100,101}
EndMacro
Macro MakeHighLowCloseOpenDemoData()
    Variable n=20
    Make/O/D/N=(n) day
    // start at midnight+1 second
    String todaysDate= Secs2Date(datetime, -2, ";")
    Variable year= str2num(StringFromList(0,todaysDate))
    Variable month= str2num(StringFromList(1,todaysDate))
    Variable today= str2num(StringFromList(2,todaysDate))
    today= date2secs(year, month, today)
    day= today+p*60*60*24
    SetScale d, 0,0,"dat", day
    Make/O/N=(n) openPrice, highPrice, lowPrice, closePrice
    closePrice = 100+gnoise(4)
    openPrice[1,]= closePrice[p-1]
    openPrice[0] = closePrice[0]-gnoise(2)
    lowprice= (openPrice+closePrice)/2 + gnoise(max(1,abs(openPrice-closePrice)))
    lowPrice= min(lowPrice, min(openPrice,closePrice))
    highprice= (openPrice+closePrice)/2 + gnoise(max(1,abs(openPrice-closePrice)))
    highPrice= max(highPrice, max(openPrice,closePrice))
    Edit day, openPrice, lowPrice, highPrice, closePrice
    ModifyTable format(day)=6
    Display
    DoAlert 0, "Choose \"Append High Low Close Open Trace\" from the Graph's \"High Low Close Open Trace\" menu."
HighLowCloseOpen.ipf (8.02 KB)
