Stacked plots / Multiple plots LAYOUT
Similar to:
http://www.igorexchange.com/node/7210
but displays existing graphs in a single layout page. Note, that the layout is set to a custom size to preserve the original, absolute graph sizes. The entire layout may then be saved as a single graph. Execute the following to try it:
make/D/O/N=1000 aa, bb, cc, dd setscale/i x, 0, 3*pi, "", aa,bb, cc, dd aa=sin(x); display aa bb=cos(x); display bb cc=tan(x); display cc dd=abs(sin(x)); display dd
Then use the snippet...
function MultiGraphLayout(GraphList, nCols, spacing, layoutName) string GraphList // semicolon separated list of graphs to be appended to layout variable nCols // number of graph columns string layoutName // name of the layout variable spacing // spacing between graphs in points! // how many graphs are there and how many rows are required variable nGraphs = ItemsInList(GraphList) variable nRows = ceil(nGraphs / nCols) variable LayoutWidth, LayoutHeight variable gWidth, gHeight variable maxWidth = 0, maxHeight = 0 variable left, top variable i, j, n = 0 string ThisGraph // detect total layout size from individual graph sizes; get maximum graph size as column/row size for(i=0; i<nGraphs; i+=1) ThisGraph = StringFromList(i, GraphList) GetWindow $ThisGraph gsize gWidth = (V_right - V_left) gHeight = (V_bottom - V_top) // update maximum maxWidth = gWidth > maxWidth ? gWidth : maxWidth maxHeight = gHeight > maxHeight ? gHeight : maxHeight endfor // calculate layout size LayoutWidth = maxWidth * nCols + ((nCols + 1) * spacing) LayoutHeight = maxHeight * nRows + ((nRows +1) * spacing) // make layout; kill if it exists DoWindow $layoutName if(V_flag) KillWindow $layoutName endif NewLayout/N=$layoutName/K=1/W=(517,55,1451,800) LayoutPageAction size=(LayoutWidth, LayoutHeight), margins=(0,0,0,0) ModifyLayout mag=0.75 //append graphs top = spacing for(i=0; i<nRows; i+=1) // reset vertical position for each column left = spacing for (j=0; j< nCols; j+=1) ThisGraph = StringFromList(n, GraphList) if(strlen(ThisGraph) == 0) return 0 endif GetWindow $ThisGraph gsize gWidth = (V_right - V_left) gHeight = (V_bottom - V_top) AppendLayoutObject/F=0 /D=1 /R=(left, top, (left + gWidth), (top + gHeight)) graph $ThisGraph // shift next starting positions to the right left += maxWidth + spacing // increase plot counter n += 1 endfor // shift next starting positions dwon top += maxHeight + spacing endfor return 1 end
...and append all graphs into one layout with:
MultiGraphLayout(WinList("*", ";", "WIN:1"), 2, 20, "AllGraphLayout")
