Round error value to appropriate significant figures
If first significant figure is "1", the value is rounded to the next digit.
If first significant figure is different from "1", the value is rounded to this digit.
Some Examples:
0.00125 --> 0.0013
1.2 --> 1.2
0.35 --> 0.4
0.4 --> 0.4
// Function to determine significant figures Function Sig_Fig(V_Error) Variable V_Error Variable V_Result print "V_Error: "+num2str(V_Error) String S_Error String S_Result // Calculate power of 10 of Value Variable V_Error_p10 = (floor(log(abs(V_Error)))) print "V_Value_p10: "+num2str(V_Error_p10) Variable V_Value V_Value = V_Error/(10^(V_Error_p10)) print "V_Value_SF: "+num2str(V_Value) // Convert number to the style "x.xx" // Convert this to a string S_Error = num2str(V_Value) print S_Error // Now check whether first character in string is a 1 String first_char = S_Error [0] print first_char if((cmpstr(first_char,"1")==0)) // If "1", round to the next significant number: S_Result = first_char+S_Error [1]+S_Error [2]+S_Error [3] // "1.23" V_Result = (round(str2num(S_Result)*10))/10 else // If other than "1", round to this significant number: S_Result = first_char+S_Error [1]+S_Error [2] // "2.3" V_Result = round(str2num(S_Result)) endif // Reconstruct value by using original power of ten: V_Result = V_Result*(10^(V_Error_p10)) print V_Result return V_Result End
