Return Input Number to Arbitrary Precision
Two functions to take an input number and return it with a reduced precision. First function does this "by hand" second uses APMath function. Motivation for this function was to enable getting a simple increment for a set variable control from an arbitrary input, which is unlikely to be an integer. Note that precision follows APMath convention that precision is number of decimal places rather than number of digits.
 Function ChangePrecision(vNum, vPrecision, vPreserveSign)
    Variable vNum       //input number to operate on
    Variable vPrecision //output precision (number of decimal places)
    Variable vPreserveSign  //1 == retain sign of input
    Variable vReturn
    Variable vExponent
    Variable vMantissa
    Variable vPwr
    Variable vSign
//this will cause an error with the log fcn
    if(vNum == 0)
//precision less than 0 makes no sense
    if(vPrecision < 0)
        return vNum
//store sign of input and ensure input is positive
    vSign = sign(vNum)
    vNum = abs(vNum)
//get mantissa of number
    vExponent = floor(log(vNum))
    vPwr =  (1 *10^vExponent)
    vMantissa = vNum / vPwr
//change mantissa to desired precision
    vMantissa = (round(vMantissa * 10^vPrecision)) / 10^vPrecision
    vReturn = (vMantissa) * vPwr
//if requested, change to original sign
    if(vPreserveSign == 1)
        vReturn *= vSign
//  Print log(vNum),vExponent, vmantissa, vPwr, vSign
    return vReturn
Function ArbPrec(vNum, vPrecision, vPreserveSign)
    Variable vSign
    Variable vOutput
    String sNum
    if(vPrecision < 0)
        return vNum
    vSign = sign(vNum)
    vNum *= vSign //same as abs(vNum)
//change to desired precision
    APMath/N=(vPrecision) sNum = vNum
    vOutput = str2num(sNum)
        vOutput *= vSign
    return vOutput
