Respond to clicking any control on a window
To use this snippet, paste the code below into an Igor procedure window. Make sure to modify the section in the first function that says
<do something here to respond to the click if you wish>
You'll need to set the first function to be a named window hook for any window you want to use this technique in. To do that, from a function or the command line execute something like this:
SetWindow kwTopWin,hook(windowClick)=RespondToWindowClick
For more information about the parameters used in these functions and additional functionality read the code comments at the top of each function.
//** // This is the window hook function. All windows that should be handled by this // function need to have this function set as a named window hook for the window. // For example: // SetWindow kwTopWin,hook(windowClick)=RespondToWindowClick // // Note: The variable names used may imply that the control has to be an actual // button, however that is not the case. Any type of control can be used. To handle // clicks on only certain types of controls, modify the "buttonFound = FindControl(s, buttonPressed)" // line. See the comments above the FindControl() function for more information. // // Note: As written this function can only handle actual Igor control types (Buttons, SetVariables, etc.). // However, it would be relatively easy to modify the code to handle something like a graph annotation. //* Function RespondToWindowClick(s) STRUCT WMWinHookStruct &s switch (s.eventCode) Case 3: // mouse down String buttonPressed = "" Variable buttonFound buttonFound = FindControl(s, buttonPressed) // Change the color and frame of the button to make // it looked like it has been toggled. if (buttonFound) <do something here to respond to the click if you wish> return 1 endif break EndSwitch return 0 End //** // Determines if the mouse cursor is currently over a control // and provides the name of the control. // // @param s // This is an instance of the WMWinHookStruct structure which // is the structured that is passed to a named window hook function. // @param controlName // Name of control the the mouse cursor is currently over. This is // the output parameter of this function. // @param controlType // [OPTIONAL] If provided, only controls of this type will be considered. // For a list of types and their meanings, look at the ControlInfo // command help and look at the V_flag parameter set for each control type. // By default, the type of a control is ignored. // @param excludedState // [OPTIONAL] If non-zero, controls will be considered from consideration // if they are disabled and/or hidden. Use the following values to exclude // controls in the following states: // Value State // 1 Hidden // 2 Disabled (but visible) // 3 Hidden OR Disabled (but visible) // By default, the disable state of a control is ignored. // // @return // If a control was found meeting the criteria specified in the parameters, // the function will return 1. If no control is found, 0 will be returned. //* Function FindControl(s, controlName, [controlType, excludedState]) STRUCT WMWinHookStruct &s String &controlName Variable controlType Variable excludedState Variable controlFound controlName = "" if (ParamIsDefault(controlType)) // Match all types of controls controlType = 0 endif String controlList = ControlNameList(s.winName, ";", "*") Variable numControls = ItemsInList(controlList, ";") String currentControlName Variable n For (n=0; n<numControls; n+=1) currentControlName = StringFromList(n, controlList, ";") ControlInfo/W=$(s.winName) $(currentControlName) // Exclude this control if only controls of a certain type should // be considered. if (controlType != 0 && controlType != V_flag) continue endif // Possibly exclude this control if it is hidden or disabled if (V_disable != 0) if (V_disable & excludedState) continue endif endif // Determine if this control was clicked on. Variable controlClicked controlClicked = DoesCursorOverlap(s, V_height, V_width, V_top, V_left) if (controlClicked) controlName = currentControlName controlFound = 1 endif EndFor return controlFound End //** // Determines if the current mouse position falls within a certain boundary. // // @param s // This is an instance of the WMWinHookStruct structure which // is the structured that is passed to a named window hook function. // @param V_height // Height of target area, in pixels. // @param V_width // Width of target area, in pixels. // @param V_top // Top of target area, in pixels. // @param V_left // Left of target area, in pixels. // // @return // If the mouse cursor overlaps the target area, 1 is returned. Otherwise, 0 is returned. //* Function DoesCursorOverlap(s, V_height, V_width, V_top, V_left) STRUCT WMWinHookStruct &s Variable V_height Variable V_width Variable V_top Variable V_left // Check vertical location if (s.mouseLoc.v >= V_top && s.mouseLoc.v <= V_top + V_height) // Check horizontal location if (s.mouseLoc.h >= V_left && s.mouseLoc.h <= V_left + V_width) return 1 endif endif return 0 End
