Rebin large set of x-y data on log-scale
ilavsky
//This routine will rebin approximately linearly distributed data into approximately logarithmically spaced data. //It will replace the input Wx and Wy with new Wx and Wy with the required NumberOfPoints //Code will replace all other input data also, so make sure you pass in only copies of the data. //If MinStep > 0 it will try to set the values so the minimum step of the log scale is MinStep //note: there are some limits on step size and number of points in and out. Basically, the step size needs to be //approximately equivalent the linear step. It cannot be much larger. And number of new points must be significantly smaller than input num points. //optional Wsdev and Wxsdev are standard deviation for each Wy (and Wx) value, they will be propagated through - sum(sdev^2)/numpnts for each bin. //optional Wxwidth will generate width of each new bin in x. NOTE: the edge is half linear distance between the two points, no log //skewing is done for edges. Therefore the width is really half of the distance between p-1 and p+1 points. //optional W1-W5 will be averaged for each bin, so this is way to propagate other data one may need to. //********************************************************************************************************** Function RebinLogData(Wx,Wy,NumberOfPoints,MinStep,[Wsdev,Wxsdev,Wxwidth,W1, W2, W3, W4, W5]) Wave Wx, Wy Variable NumberOfPoints, MinStep Wave Wsdev, Wxsdev Wave Wxwidth Wave W1, W2, W3, W4, W5 variable CalcSdev, CalcxSdev, CalcWidth, CalcW1, CalcW2, CalcW3, CalcW4, CalcW5 CalcSdev = ParamIsDefault(Wsdev) ? 0 : 1 CalcxSdev = ParamIsDefault(Wxsdev) ? 0 : 1 CalcWidth = ParamIsDefault(Wxwidth) ? 0 : 1 CalcW1 = ParamIsDefault(W1) ? 0 : 1 CalcW2 = ParamIsDefault(W2) ? 0 : 1 CalcW3 = ParamIsDefault(W3) ? 0 : 1 CalcW4 = ParamIsDefault(W4) ? 0 : 1 CalcW5 = ParamIsDefault(W5) ? 0 : 1 variable OldNumPnts=numpnts(Wx) if(3*NumberOfPoints>OldNumPnts) print "User requested rebinning of data, but old number of points is less than 3*requested number of points, no rebinning done" return 0 endif variable StartX, EndX, iii, isGrowing, CorrectStart, logStartX, logEndX if(Wx[0]<=0) //log scale cannot start at 0, so let's pick something close to what user wanted... Wx[0] = Wx[1]/2 endif CorrectStart = Wx[0] if(MinStep>0) StartX = FindCorrectLogScaleStart(Wx[0],Wx[numpnts(Wx)-1],NumberOfPoints,MinStep) else StartX = CorrectStart endif Endx = StartX +abs(Wx[numpnts(Wx)-1] - Wx[0]) isGrowing = (Wx[0] < Wx[numpnts(Wx)-1]) ? 1 : 0 make/O/D/FREE/N=(NumberOfPoints) tempNewLogDist, tempNewLogDistBinWidth logstartX=log(startX) logendX=log(endX) tempNewLogDist = logstartX + p*(logendX-logstartX)/numpnts(tempNewLogDist) tempNewLogDist = 10^(tempNewLogDist) startX = tempNewLogDist[0] tempNewLogDist += CorrectStart - StartX tempNewLogDistBinWidth[1,numpnts(tempNewLogDist)-2] = tempNewLogDist[p+1] - tempNewLogDist[p-1] tempNewLogDistBinWidth[0] = tempNewLogDistBinWidth[1] tempNewLogDistBinWidth[numpnts(tempNewLogDist)-1] = tempNewLogDistBinWidth[numpnts(tempNewLogDist)-2] make/O/D/FREE/N=(NumberOfPoints) Rebinned_WvX, Rebinned_WvY, Rebinned_Wv1, Rebinned_Wv2,Rebinned_Wv3, Rebinned_Wv4, Rebinned_Wv5, Rebinned_Wsdev, Rebinned_Wxsdev Rebinned_WvX=0 Rebinned_WvY=0 Rebinned_Wv1=0 Rebinned_Wv2=0 Rebinned_Wv3=0 Rebinned_Wv4=0 Rebinned_Wv5=0 Rebinned_Wsdev=0 Rebinned_Wxsdev=0 variable i, j variable cntPoints, BinHighEdge //variable i will be from 0 to number of new points, moving through destination waves j=0 //this variable goes through data to be reduced, therefore it goes from 0 to numpnts(Wx) For(i=0;i<NumberOfPoints;i+=1) cntPoints=0 BinHighEdge = tempNewLogDist[i]+tempNewLogDistBinWidth[i]/2 if(isGrowing) Do Rebinned_WvX[i] += Wx[j] Rebinned_WvY[i] += Wy[j] if(CalcW1) Rebinned_Wv1[i] += W1[j] endif if(CalcW2) Rebinned_Wv2[i] += W2[j] endif if(CalcW3) Rebinned_Wv3[i] += W3[j] endif if(CalcW4) Rebinned_Wv4[i] += W4[j] endif if(CalcW5) Rebinned_Wv5[i] += W5[j] endif if(CalcSdev) Rebinned_Wsdev[i] += Wsdev[j]^2 endif if(CalcxSdev) Rebinned_Wxsdev[i] += Wxsdev[j]^2 endif cntPoints+=1 j+=1 While(Wx[j-1]<BinHighEdge && j<OldNumPnts) else Do Rebinned_WvX[i] += Wx[j] Rebinned_WvY[i] += Wy[j] if(CalcW1) Rebinned_Wv1[i] += W1[j] endif if(CalcW2) Rebinned_Wv2[i] += W2[j] endif if(CalcW3) Rebinned_Wv3[i] += W3[j] endif if(CalcW4) Rebinned_Wv4[i] += W4[j] endif if(CalcW5) Rebinned_Wv5[i] += W5[j] endif if(CalcSdev) Rebinned_Wsdev[i] += Wsdev[j]^2 endif if(CalcxSdev) Rebinned_Wxsdev[i] += Wxsdev[j]^2 endif cntPoints+=1 j+=1 While((Wx[j-1]>BinHighEdge) && (j<OldNumPnts)) endif Rebinned_WvX[i]/=cntPoints Rebinned_WvY[i]/=cntPoints if(CalcW1) Rebinned_Wv1[i]/=cntPoints endif if(CalcW2) Rebinned_Wv2[i]/=cntPoints endif if(CalcW3) Rebinned_Wv3[i]/=cntPoints endif if(CalcW4) Rebinned_Wv4[i]/=cntPoints endif if(CalcW5) Rebinned_Wv5[i]/=cntPoints endif if(CalcSdev) Rebinned_Wsdev[i]=sqrt(Rebinned_Wsdev[i])/cntPoints endif if(CalcxSdev) Rebinned_Wxsdev[i]=sqrt(Rebinned_Wxsdev[i])/cntPoints endif endfor Redimension/N=(numpnts(Rebinned_WvX))/D Wx, Wy Wx=Rebinned_WvX Wy=Rebinned_WvY if(CalcW1) Redimension/N=(numpnts(Rebinned_WvX))/D W1 W1=Rebinned_Wv1 endif if(CalcW2) Redimension/N=(numpnts(Rebinned_WvX))/D W2 W2=Rebinned_Wv2 endif if(CalcW3) Redimension/N=(numpnts(Rebinned_WvX))/D W3 W3=Rebinned_Wv3 endif if(CalcW4) Redimension/N=(numpnts(Rebinned_WvX))/D W4 W4=Rebinned_Wv4 endif if(CalcW5) Redimension/N=(numpnts(Rebinned_WvX))/D W5 W5=Rebinned_Wv5 endif if(CalcSdev) Redimension/N=(numpnts(Rebinned_WvX))/D Wsdev Wsdev = Rebinned_Wsdev endif if(CalcxSdev) Redimension/N=(numpnts(Rebinned_WvX))/D Wsdev Wxsdev = Rebinned_Wxsdev endif if(CalcWidth) Redimension/N=(numpnts(Rebinned_WvX))/D Wxwidth Wxwidth = tempNewLogDistBinWidth endif end //********************************************************************************************************** Function FindCorrectLogScaleStart(StartValue,EndValue,NumPoints,MinStep) variable StartValue,EndValue,NumPoints,MinStep Make/Free/N=3 w w={EndValue-StartValue, NumPoints,MinStep} Optimize /H=100/L=1e-5/I=100/T=(MinStep/10)/Q myFindStartValueFunc, w //the optimize parameters: 10^H is last reasonable number, 10^L is really close to 1, other are open for discussion. //Test this works if you want to make sure... // variable startX=log(V_minloc) // variable endX=log(V_minloc+range) // variable LastMinStep = 10^(startX + (endX-startX)/NumPoints) - 10^(startX) // print LastMinStep return V_minloc end //********************************************************************************************************** static Function myFindStartValueFunc(w,x1) //static to keep this form polluting names others may use. Wave w //this is {totalRange, NumSteps,MinStep} Variable x1 //this is startValue where we need to start with log stepping... variable LastMinStep = 10^(log(X1) + (log(X1+w[0])-log(X1))/w[1]) - 10^(log(X1)) return abs(LastMinStep-w[2]) End //*****************************************************************************************************************
