Popup Menu of Root DataFolders
// This example shows a panel popup menu to list data folders from the root level
// It excludes the Packages folder from the list
// The New selection allows you to create a new data folder from the root level
// NOTE: this does NOT set the location to the folder ... see the comments for details
Function MakePanel()
	// make a sample panel
	// ... (use your own values here)
	NewPanel/W=(10,10,50,50)
	// strings for popup menu
	string theTopFldr = StringFromList(0,ListofRootDataFolders())
	string fldrList = "ListofRootDataFolders()"
	// popup menu location, size, and title (change these as you desire)
	PopupMenu FolderList,pos={5,13},size={84,20},title="root:"
	// popup menu mode, popvalue, value, and procedure
        // do not change these
	PopupMenu FolderList, mode=1, popvalue=theTopFldr
        PopupMenu FolderList, value=#fldrList, proc=ChangeFolder
// function to return list of root data folders
Function/S ListofRootDataFolders()
	string LoFldrs="New;\M1-;", theOne
	variable ic = 0
	do
		theOne = GetIndexedObjName("root:",4,ic)
		if (strlen(theOne)==0)
			break
		LoFldrs +=  theOne + ";"
		ic += 1
	while(1)
	LoFldrs = RemoveFromList("Packages",LoFldrs)
	if (strlen(LoFldrs)==0)
		LoFldrs = "-- none --"
	return LoFldrs
// function to change the data folder
Function ChangeFolder(pa) : PopupMenuControl
	STRUCT WMPopupAction &pa
	string theFldr = ""
	switch( pa.eventCode )
		case 2: // mouse up
	              switch(pa.popNum)
			case 1:		// selection is "New"
			        prompt theFldr, "New folder name?"
				DoPrompt "New Folder", theFldr
				if (V_flag==1)
					break
				if (strlen(theFldr)==0)
					break
                                // create the new folder (but do not go there)
				NewDatafolder/O $theFldr
				PopupMenu FolderList, mode=(ItemsInList(ListofRootDatafolders()))
				break
			// put your other cases here for different folders
			// case ....
		     endswitch
		     ControlUpdate FolderList
                    // put code here to do something when a folder is selected
		    break
	endswitch
