Müller's Method (find a complex root of an analytic function)
FindRoots
operation will provide complex roots to polynomials with real coefficients, it does not work for other functions with complex roots. The code is light on user-interface features and has not been extensively tested. Please email suggestions or comments.Müller's method uses three initial evaluations of a function but does not require the derivative of the function. Essentially, the method fits a parabola through the last three points and uses the appropriate intersection with zero as its next value. Unlike other methods, you can start from a real guess and still find a complex root. The code is based on Numerical Recipes, 2nd ed. See also the Wikipedia entry.
Example:
•print sin(pi/3)
0.866025
•print /C Muller(cmplx(1,0.1),cmplx(1,0.2),cmplx(1,0.3)) // 1st root of z^3+1=0 (<pre><code class="language-igor"> FindRoots
would work on this example)
(0.5,0.866025)
•print /C Muller(cmplx(1,-0.1),cmplx(1,-0.2),cmplx(1,-0.3)) // 2nd root of z^3+1=0
(0.5,-0.866025)
•print /C Muller(cmplx(-0.7,0),cmplx(-0.8,0),cmplx(-0.9,0)) // 3rd root of z^3+1=0 (the obvious one)
(-1,0)
•print /C Muller(cmplx(0,-0.6),cmplx(0,-0.7),cmplx(0,-0.8)) // root of sqrt(z+1+i)+1 (this is something FindRoots
can't do)
(3,-1)
Function/C Muller(x0,x1,x2) Variable/c x0,x1,x2 // initial values for root iteration Variable tol=1e-9,nmax=100,k=2 // tol = tolerance; nmax = max iterations (adjust to taste) Make /c/d/o/n=(nmax+3) xx=0,f=0 // temporary waves [keep when debugging] xx[0]=x0; xx[1]=x1; xx[2]=x2 // initial values in waves f[0] = myfunc(x0); f[1] = myfunc(x1); f[2] = myfunc(x2) // and their function values Do xx[k+1] = Muller_step(xx[k],xx[k-1],xx[k-2],f[k],f[k-1],f[k-2]) f[k+1] = myfunc(xx[k+1]) // Muller requires only one functional eval /iteration k += 1 While ((k<nmax+3) && (cabs(xx[k]-xx[k-1]) > tol)) // deletepoints k+1,nmax-k+2, xwave,fwave // delete "unused" points and keep waves for debug Variable /c root = xx[k] Killwaves xx,f // delete waves (normal operation) Return root End Function/C Muller_step(xk,xk1,xk2,fk,fk1,fk2) // from Numerical Recipes, 2nd ed. Variable/C xk,xk1,xk2,fk,fk1,fk2 // initial values Variable/C q,A,B,C // use complex quantities (/c flag) q = (xk-xk1)/(xk1-xk2) A = q*fk-q*(1+q)*fk1+q^2*fk2 B = (2*q+1)*fk - (1+q)^2*fk1 + q^2*fk2 C = (1+q)*fk Variable/c d = Sqrt(Cmplx(B^2-4*A*C,0)) // it's this step that can make a real guess go complex if (Magsqr(B+d) > Magsqr(B-d)) Return xk - (xk-xk1)*2*C/(B+d) else Return xk - (xk-xk1)*2*C/(B-d) endif End Function/c myfunc(z) // your analytic function Variable/c z // Return z^3+1 // FindRoots could actually do this one Return Sqrt(z+Cmplx(1,1))-2 // but it can't do this one End
Bech has posted a useful snippet to find complex roots. I have takent the liberty of adding to its flexibility and making it more consistent with other Igor operation syntax:
(1) added a parameter wave to argument list
(2) passed a user specified function to Muller() using FUNCREF definition (with added prototype function)
The latter usage means that you may not have to alter either the Muller() code or the function code, if you wish to use a different function.
Bech's earlier Muller_step() code remains unchanged.
I have also shown an example function (TM mode of a dielectric waveguide) that Muller is capable of solving. This example is used within other functions, so a History snippet example is not informative.
April 14, 2010 at 06:19 am - Permalink
