Merge Experiment(s) to Current
// This snippet puts up a dialog box to select multiple experiments to MERGE in to the current experiment // Caveats apply -- please read about MERGING EXPERIMENTS before you use this #pragma rtGlobals=1 // Use modern global access method. Function MergeSelectedtoCurrent() string theCmd variable refNum, ic, nExp Open/D/R/MULT=1/F="Igor Prop Experiments (*.pxp):.pxp;"/M="Select experiments to merge" refNum if (strlen(S_filename)==0) return 0 endif nExp = ItemsInList(S_filename,"\r") for (ic=0;ic<nExp;ic+=1) sprintf theCmd, "MERGEEXPERIMENT %s", StringFromList(ic,S_filename,"\r") Execute/P/Q theCmd endfor return 0 end
