Loading/unloading of procedure files from User Procedures folder
thomas_braun
Just add the desired procedure file in the panel and then load/unload it with one click or CTRL+6 to siwtch the included state.
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
#pragma version=0.1
#pragma igorVersion=6.3
#pragma IndependentModule=IncludeLoader
// Author: thomas aht braun dot byte minus physics dot de
// Feb 2018
static StrConstant panel = "IncludeLoader"
Menu "MyMacros"
"IncludeLoader",/Q, CreatePanel()
"Switch Inluded State/6",/Q, SwitchState()
Function CreatePanel()
DoWindow $panel
if(V_Flag)
KillWindow $panel
NewPanel/W=(150,77,350,150)/N=$panel/K=1
Button button0,pos={76,7},size={50,20},proc=$(GetIndependentModuleName() + "#ButtonProcLoadUnload")
SetVariable setvar0,pos={37,38},size={159,16},title="Includes: "
SetVariable setvar0,value= _STR:""
UpdatePanel()
static Function/S GetIncludes()
DoWindow $panel
if(!V_Flag)
return ""
ControlInfo/W=$panel setvar0
return S_value
static Function isIncludeLoaded()
string includeFiles = GetIncludes()
/// @todo handle properly
string includeFile = StringFromList(0, includeFiles)
string list = WinList(includeFile + ".ipf", ";", "WIN:128")
return ( strlen(list) != 0 )
Function SwitchState()
variable i, numItems
string includeFile, includeFiles
numItems = ItemsInList(includeFiles)
for(i = 0; i < numItems; i += 1)
includeFile = StringFromList(i, includeFiles)
if(isIncludeLoaded())
Execute/P/Q "DELETEINCLUDE \"" + includeFile + "\""
Execute/P/Q "INSERTINCLUDE \"" + includeFile + "\""
Execute/P/Q/Z "COMPILEPROCEDURES "
// update the panel after loading/unloading the include
Execute/P/Q/Z GetIndependentModuleName() + "#UpdatePanel()"
Function ButtonProcLoadUnload(ba) : ButtonControl
STRUCT WMButtonAction &ba
switch(ba.eventCode)
case 2: // mouse up
SwitchState()
break
break
endswitch
Function UpdatePanel()
Button button0, win=$panel, title="Unload"
Button button0, win=$panel, title="Load"
#pragma version=0.1
// Feb 2018
Menu "MyMacros"
DoWindow $panel
if(V_Flag)
KillWindow $panel
UpdatePanel()
DoWindow $panel
if(!V_Flag)
return ""
return S_value
case 2: // mouse up
SwitchState()
break
break
endswitch
Here is a slightly different version that uses listboxes to select files to be loaded or unloaded, and populates these with the names of available procedure files. Since this should be run as an independent module, the code must sit in its own procedure window. I've attached a procedure file.
-- edited to remove attachment. more recent version of procedure loader is here.
July 23, 2018 at 08:45 am - Permalink
