    Load Square Image From 1D Data File
#pragma rtGlobals=3 // Use modern global access method. // This procedure was written to load a text data file written by Spyglass Transform software. // The file represented a square matrix but was written with all of the values // in one column. For example, a matrix like this: // 1 2 3 // 2 3 4 // 5 6 7 // would be written as: // 1 // 2 // ... // 7 // The function loads the data, redimensions it, and creates an image plot. // To load a non-square image you will have to modify the procedure. // See the comments below for further details. Menu "Load Waves" "Load Square Image From 1D Data File...", LoadSquareImageFrom1DDataFile("", "") End // LoadSquareImageFrom1DDataFile(pathName, filePath) // The file is expected to contain a single column of numbers which represent // an image of nxm dimensions where n==m (i.e., a square matrix). // This function loads and plots the data. The wave name is based on the file name. // NOTE: If the wave already exists it is overwritten. Function LoadSquareImageFrom1DDataFile(pathName, filePath) String pathName // Name of an Igor symbolic path or "". String filePath // Name of file or full path to file. // First get a valid reference to a file. if ((strlen(pathName)==0) || (strlen(filePath)==0)) // Display dialog looking for file. Variable refNum Open/D/R/P=$pathName refNum as filePath filePath = S_fileName // S_fileName is set by Open/D if (strlen(filePath) == 0) // User cancelled? return -2 endif endif // Generate a wave name based on the file name String name = ParseFilePath(3, filePath, ":", 0, 0) // Get file name without extension name = CleanupName(name, 0) // Make name kosher. // Generate parameter for LoadWave /B flag to set the wave name String columnInfoStr = "N=" + name + ";" // Load the data as 1D LoadWave/G/D/P=$pathName/O/A/B=columnInfoStr filePath if (V_flag == 0) // No waves loaded? Beep Print "No data found in file" return -3 // Something went wrong endif // Create a wave reference for the wave created by LoadWave Wave w = $name // Redimension as 2D assuming square image Variable numPoints = numpnts(w) Variable numRows = sqrt(numPoints) Variable numColumns = numRows if (numRows*numColumns != numPoints) Beep Printf "NOTE: LoadSquareImageFrom1DDataFile expected a square array but got %d points\r", numPoints endif Redimension /N=(numRows,numColumns) w // Create an image plot String plotName = name + "_G" // G for "graph" if (strlen(plotName) > 29) // Name are limited to 31 character and we have to plotName = "Image" // leave room for possible digits to make name unique endif if (Exists(plotName)!=0 || WinType(plotName)!=0) // Name already in use? plotName = UniqueName(plotName, 6, 0) endif NewImage /N=$plotName w // Set plot title DoWindow/T $plotName, name return 0 End
