Load Double-Quoted Text Data File
hrodstein
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
// The LoadDoubleQuotedTextDataFile procedure loads data files in which text is double-quoted, like this:
// "<ColumnName>"<comma>"<ColumnName>"
// "<string possibly containing comma>"<comma>"<string possibly containing comma>"...
// The file may also contain numeric columns, like this:
// "<string possibly containing comma>"<comma><number>...
// LoadWave by itself does not handle this because the comma inside the double-quoted string is taken as a column delimiter.
// To load this, LoadDoubleQuotedTextDataFile does the following:
// 1. Create a temporary file in which the true comma delimiters (those outside the quotes) are replaced by tabs
// and the quotes are removed.
// 2. Load the temporary file.
// 3. Delete the temporary file.
// This also works on tab-delimited test files containing double-quotes that you don't want to load, e.g.:
// "<string>"<tab>"<string>"...
// These set the initial values in the dialog displayed by LoadDoubleQuotedTextDataFile.
// You can customize them for your file if you like.
static Constant kDefaultNameLine = 0
static Constant kDefaultFirstDataLine = 0
static Constant kDefaultNumDataLines = 0
static Constant kDefaultFirstColumnToLoad = 0
static Constant kDefaultNumColumnsToLoad = 0
Menu "Load Waves"
"Load Double-Quoted Text Data File . . .", LoadDoubleQuotedTextDataFile("", "")
static Function/S CleanupText(origText, cleanedText)
String origText // Input
String& cleanedText // Output
Variable numOrigBytes = strlen(origText)
// This speeds things up by avoiding resizing the output string over and over again
cleanedText = PadString("", numOrigBytes, 32)
Variable numOutputBytes = 0
String doubleQuoteStr = "\""
String commaStr = ",", tabStr = "\t"
Variable inDoubleQuote = 0
Variable i
for(i=0; i<numOrigBytes; i+=1)
Variable skip = 0
String byte = origText[i]
if (CmpStr(byte,doubleQuoteStr) == 0)
skip = 1
inDoubleQuote = !inDoubleQuote // We are either entering or leaving a double-quoted string
if (CmpStr(byte,commaStr) == 0)
if (!inDoubleQuote)
// This is a delimiter comma - replace it with tab
byte = tabStr
if (!skip)
cleanedText[numOutputBytes] = byte
numOutputBytes += 1
cleanedText = cleanedText[0,numOutputBytes-1]
return cleanedText
static Function TestCleanupText()
String origText = "\"Quick brown, fox\",\"0\""
String cleanedText
Print cleanedText
static Function CreateCleanedUpTempFile(pathName, origFileName, tempFileName)
String pathName // Symbolic path name
String origFileName
String tempFileName // Name to use for temporary file
Variable origRefNum
Open /R /P=$pathName /Z origRefNum as origFileName
if (V_flag != 0)
Print "Error opening " + origFileName
return -1 // Error of some kind
FStatus origRefNum
Variable numBytesInOrigFile = V_logEOF
String origText = PadString("", numBytesInOrigFile, 32)
FBinRead origRefNum, origText
Close origRefNum
String cleanedText = CleanupText(origText, cleanedText)
Variable tempRefNum
Open /P=$pathName /Z tempRefNum as tempFileName
if (V_flag != 0)
Print "Error opening " + tempFileName
FBinWrite tempRefNum, cleanedText
Close tempRefNum
static StrConstant kExtensionStr = "????" // Shows files with any extension. Change to, e.g., ".dat", to show just .dat files.
// LoadDoubleQuotedTextDataFile(pathName, fileName, [nameLine, firstDataLine, numDataLines, firstColumn, numColumns])
// nameLine, firstDataLine, numDataLines, firstColumn and numColumns are optional parameters.
// If you omit them, LoadDoubleQuotedTextDataFile displays a dialog in which the user can enter them
Function LoadDoubleQuotedTextDataFile(pathName, fileName, [nameLine, firstDataLine, numDataLines, firstColumn, numColumns])
String pathName // Name of an Igor symbolic path or ""
String fileName // Name of file or full path to file
// Optional parameters
Variable nameLine
Variable firstDataLine
Variable numDataLines
Variable firstColumn
Variable numColumns
if (ParamIsDefault(nameLine) || ParamIsDefault(firstDataLine) || ParamIsDefault(numDataLines) || ParamIsDefault(firstColumn) || ParamIsDefault(numColumns))
// The caller did not supply optional parameters so display dialog
// These set the initial values displayed in the dialog
nameLine = kDefaultNameLine
firstDataLine = kDefaultFirstDataLine
numDataLines = kDefaultNumDataLines
firstColumn = kDefaultFirstColumnToLoad
numColumns = kDefaultNumColumnsToLoad
// Display dialog
Prompt nameLine, "Line containing column names (zero-based - 0 if no column names): "
Prompt firstDataLine, "First line containing data (zero-based): "
Prompt numDataLines, "Number of data lines to load (zero for all): "
Prompt firstColumn, "First column to load (zero-based): "
Prompt numColumns, "Number of columns to load (zero for all): "
DoPrompt "Enter LoadWave Parameters", nameLine, firstDataLine, numDataLines, firstColumn, numColumns
if (V_Flag)
return -1 // User canceled
Variable refNum
String message
// First get a valid reference to a file.
if ((strlen(pathName)==0) || (strlen(fileName)==0))
// Display dialog looking for file.
message = "Select double-quoted text data file"
Open /D /R /P=$pathName /T=kExtensionStr /M=message refNum as fileName
fileName = S_fileName // S_fileName is set by Open/D
if (strlen(fileName) == 0) // User cancelled?
return -1
String tempFileName = fileName + "_tmp"
if (CreateCleanedUpTempFile(pathName, fileName, tempFileName) != 0)
return -1 // Error
// Remove /D if you want to load as single-precision floating point
String delimiters = "\t"
LoadWave /O /J /D /K=0 /V={delimiters, "", 0, 0} /L={nameLine, firstDataLine, numDataLines, firstColumn, numColumns} /E=1 /Q /P=$pathName tempFileName
if (V_flag > 0)
Printf "Loaded double-quoted data from \"%s\"\r", fileName
DeleteFile /P=$pathName tempFileName
Menu "Load Waves"
Variable i
Variable skip = 0
skip = 1
if (!inDoubleQuote)
byte = tabStr
if (!skip)
numOutputBytes += 1
return cleanedText
String cleanedText
Print cleanedText
String origFileName
Variable origRefNum
if (V_flag != 0)
FStatus origRefNum
Close origRefNum
Variable tempRefNum
if (V_flag != 0)
Close tempRefNum
Variable nameLine
Variable numColumns
// Display dialog
if (V_Flag)
Variable refNum
String message
return -1
return -1 // Error
if (V_flag > 0)
