Load all files in a directory
Payam Minoofar
//This function automatically loads all files in a folder that the user selects. In this instance, the function //assumes that each file is a Dionex Chromeleon generated ASCII file, and that the chromatogram's data //points were collected at 0.2 sec. intervals. You MUST must make the changes appropriate to your data //files on the lines below marked with exclamation points!!! function loader() //initialize loop variable variable i=0 string wname,fname //wave names and file name, respectively //Ask the user to identify a folder on the computer getfilefolderinfo/D //Store the folder that the user has selected as a new symbolic path in IGOR called cgms //!!!!!!!!! if you prefer a different name, change ALL instances of cgms in the function !!!!!!!! newpath/O cgms S_path //Create a list of all files that are .txt files in the folder. -1 parameter addresses all files. // !!!!!!!!! if your files have a different extension, change .TXT below to your extension!!!!!!!!!!!! string filelist= indexedfile(cgms,-1,".TXT") //Begin processing the list do //store the ith name in the list into wname. fname = stringfromlist(i,filelist) //strip away ".txt" to get the name of the chromatogram, which is the file name //!!!!!!!!!! change the next line if you want a different name for the waves that are created !!!!!!!!!!!!!!! wname = fname[0,strlen(fname)-5] //reference a wave with the name of the chromatogram. wave w = $wname //if the referenced wave does not exist, create it. if (!waveexists(w) ) //The /L parameter tells IGOR to load no headers, and to load the 3rd column of data (indexed as 2) only //!!!!!!!! You must change this next line to tell IGOR how to load the data in each file !!!!!!!!!!!!!!! LoadWave/G/D/A=wave/P=cgms/O/L={0,0,0,2,0} stringfromlist(i,filelist) //wave created is wave0. It is renamed after the chromatogram. rename wave0 $wname //And scaled accordingly. //!!!!!!!!! you MUST change or delete the following line according to your data's scaling or lack thereof. !!!!!!!!!!!! setscale/P x,0,0.0033333,$wname //Print confirmation of what was just loaded. print "Loaded "+fname else //Othewise, tell the user that this chromatogram was previously loaded. print fname+" was previously loaded. Its corresponding wave exists." endif i += 1 //move to next file while(i<itemsinlist(filelist)) //end when all files are processed. end
