Layout Front Set (Graph + Panel)
I am frequently having to create a layout that should contain a graph with results and a panel with the inputs that generated the results. The code below will do the trick.
This snippet may also be useful to folks who use Igor Pro in classroom assignments. The layout has a stamp of information giving the experiment, user name, machine, and date + time. This may help you to police against students having the temptation to copy someone else's work.
// Layout Front Set // v 2021-11-10 jjw // create a layout with topmost figure to left, topmost panel to right // respects aspect ratios of graph and panel, override input to have graph fill its region // puts stamp of information at bottom right // requires Igor Pro 7 or greater // *** change these for your preferred layout page size // US letter page in landscape with 1/4 in margin Static Constant pgwidth = 792 Static Constant pgheight = 612 Static Constant pgmargin = 18 // set the fraction for the graph on the page left side Static Constant gfrac = 0.75 Menu "Macros" "Layout Front Set",/Q, layout_FrontSet() end // directly create layout Function layout_FrontSet() string gname, pname gname = WinName(0,1,1) pname = WinName(0,64,1) layout_results(gname, pname) return 0 end // function available to call from other routines // set gfill = 1 to have graph fill its region Function layout_results(string graphname, string panelname, [variable gfill]) // parameters variable gwidth, gheight, pwidth, pheight variable grwidth, prwidth variable gratio, pratio, wthratio variable toffset, tsize // sizes of regions for appending grwidth = gfrac*(pgwidth-2*pgmargin) prwidth = (1 - gfrac)*(pgwidth-3*pgmargin) gratio = grwidth/(pgheight-2*pgmargin) pratio = prwidth/(pgheight-2*pgmargin-4*pgmargin) // validity checks and window sizes DoWindow/F $graphname if (v_flag == 0) return -1 endif GetWindow/Z $graphname wsize gwidth = V_right - V_left; gheight = V_bottom - V_top //print gwidth, gheight DoWindow/F $panelname if (v_flag == 0) return -1 endif SavePICT/SNAP=1/O/WIN=$panelname/P=_PictGallery_/E=-5 as "PanelSnapShot" GetWindow/Z $panelname wsize pwidth = V_right - V_left; pheight = V_bottom - V_top // strings for stamp string enstr, strdt, strsys, strprbx enstr = IgorInfo(1) + "\r" strdt = date() + " " + time() strsys = IgorInfo(7) + " : " + IgorInfo(2) strprbx = "\\Z10\\JR" + enstr + strsys strprbx += "\r" + strdt // remove existing layout window to refresh KillWindow/Z SnapshotResultsLayout NewLayout/K=1/W=(30,50,600,500) as "Results Layout" DoWindow/C SnapshotResultsLayout LayoutPageAction size=(pgwidth,pgheight),margins=(pgmargin,pgmargin,pgmargin,pgmargin) ModifyLayout mag=0.5 // append graph if (ParamIsDefault(gfill)) wthratio = gwidth/gheight if (wthratio > gratio) // too wide, shrink height by ratio tsize = gheight*(grwidth/gwidth) toffset = 2*pgmargin AppendLayoutObject/F=0/T=0/R=(pgmargin,toffset,grwidth+pgmargin,tsize+toffset) Graph $graphname //print "too wide", wthratio, grwidth/tsize else // too tall, shrink width by ratio toffset = pgmargin tsize = gwidth*(pgheight-2*pgmargin)/gheight AppendLayoutObject/F=0/T=0/R=(pgmargin,toffset,tsize+pgmargin,pgheight-pgmargin) Graph $graphname //print "too tall", wthratio, tsize/(pgheight-2*pgmargin) endif else AppendLayoutObject/F=0/T=0/R=(pgmargin,pgmargin,grwidth+pgmargin,pgheight-2*pgmargin) Graph $graphname endif // append panel wthratio = pwidth/pheight SetDrawLayer ProgBack if (wthratio > pratio) //print "wide panel", pwidth, pheight, wthratio, pratio toffset = pratio*pheight - 2*pgmargin pratio = prwidth/pwidth else //print "tall panel", pwidth, pheight toffset = pgmargin pratio = (pgheight-2*pgmargin-4*pgmargin)/pheight endif DrawPICT grwidth+pgmargin,toffset,pratio,pratio,PanelSnapShot // add text stamp in draw layer (keeping it "immutable") DrawText grwidth+2*pgmargin, pgheight-1.5*pgmargin, strprbx SetDrawLayer UserFront return 0 end
