    kernel density estimation (1d)
 FastGaussTransform  can be used to create a wrapper routine.  The routine below is a minimal implementation.  The attached experiment shows how to use it on simulated data.Caution:
 FastGaussTransform  saves time for large n by clustering nearby points.  The cluster algorithm needs parameters (e.g., the /RX flag...) and the value chosen here probably does not  always work.  One symptom of "failure" is a jump discontinuity in the resulting pdf estimate. (It should be smooth.)kde is particularly nice for 2d (bivariate) data. One advantage is that you can generate smooth contours from the estimated pdf.
 FastGaussTransform  can handle such data, but it is not implemented below.Function kde(w,bw) // 1d kernel density estimation (Gaussian kernel) wave w; variable bw // w must not contain NaNs variable n=numpnts(w),kde_norm, xmin=wavemin(w)-2*bw, xmax=wavemax(w)+2*bw variable nx = min(round(100*(xmax-xmin)/bw),100) make /d/free/n=(n) wweights=1 FastGaussTransform /WDTH=(bw)/RX=(4*bw) /OUT1={xmin,nx,xmax} w,wweights // you may need to tweak /RX flag value wave M_FGT; kde_norm=sum(M_FGT)*deltax(M_FGT); M_FGT /= kde_norm string wn=NameofWave(w)+"_kde"; duplicate /d/o M_FGT $wn killwaves M_FGT End
