Jensen-Shannon divergence
http://www.igorexchange.com/node/2318
//***************************************************************************** // JSDivergence // Created 20110703 // // Shawn Driscoll // Salk Institute for Biological Studies // // Calculates the Jensen-Shannon divergence between the probability // distributions P and Q. P and Q must span the same range of values // and contain the same number of points. // // Jensen-Shannon Divergence is defined as // // JSD(P||Q) = 1/2*D(P||M) + 1/2*D(Q||M) // // where M is 1/2*(P+Q) and D(P||M) is the Kullback-Leibler divergence. // // According to Lin (1991), the Jensen–Shannon divergence is bounded by 1.0. // // 0 <= JSD(P||Q) <= 1.0 // //***************************************************************************** function JSDivergence(P,Q) //-------------------------------------------------------------------------- // parameters //-------------------------------------------------------------------------- wave P,Q; //-------------------------------------------------------------------------- // variables //-------------------------------------------------------------------------- variable n_jsd = 0; //-------------------------------------------------------------------------- // main function //-------------------------------------------------------------------------- //// // create mean distribution matrixop/free M = (P+Q)/2; //// // calculate squared jensen-shannon divergence n_jsd = 0.5*KLDivergence(P,M) + 0.5*KLDivergence(Q,M); //// // take square root since this is the actual metric n_jsd = sqrt(n_jsd); // // save to global variable variable/g v_JSDivergence = n_jsd; // // print result printf "v_JSDivergence= %g\r",n_jsd; // // return result return n_jsd; end
