Information for a package manager to retain.
andyfaff
Structure string packageName uint32 packageVersion //version number of the package. string patchLevel string packageID //packageID in the repository string packageURL string packageContact //email address of package maintainer (should this be mangled?) string md5hash //the hash of the downloaded package for some security. uint32 dateOfFirstInstall uint32 lastUpdated uint16 isCurrentlyInstalled //if it's uninstalled, then the record should still exist Wave/t fileList //a list of the files included in the package. Wave fileType //bit set for 1= Igor Procedure, 2=XOP, 3=Help File uint16 structVersion //describes this structure Endstructure
so it is flexible and easy to use. E.g. patchlevel is nice if you are doing releases from your version control system.
I don't understand your remark for the md5hash string, but maybe we should use SHA1 instead.
February 7, 2011 at 07:46 am - Permalink
I have considered whether to convert this to be in an initialization structure rather than top-level strings. Recommendations would be appreciated.
I would suggest parameters sourceURL and versioncheckURL that will denote locations of the package code and place to check for recent version, respectively.
Where are you proposing this structure is to be resident -- within each procedure file (or top level procedure file), or alternatively in a central location for each user (ie, /.../WaveMetrics/Igor Pro Package Receipts)?
February 7, 2011 at 10:50 am - Permalink
February 7, 2011 at 10:56 am - Permalink
