hrodstein's JCAMP loading procedure but slightly tweaked for our odd lab preferences
//Code written by hrodstein and tweaked by i'llbefine to accommodate for our lab preferences //which are having both the Y wave and X wave instead of using X scaling and the ability to //to use spaces and periods in naming waves (this was achieved by using the function //replaceString in order to remove the "##TITLE= " from the string and retain the entire //line instead of using sscanf and %s which cut off lines after a white space). Menu "Load Waves" "AbsUpload", AbsUpload("", "") End Function PrepareJCAMPCatalogForNewRow(jcampCatalog) WAVE/T jcampCatalog int numRows = DimSize(jcampCatalog,0) if (numRows == 0) Redimension/N=(1,5) jcampCatalog SetDimLabel 1,0,title,jcampCatalog SetDimLabel 1,1,startLine,jcampCatalog SetDimLabel 1,2,endLine,jcampCatalog SetDimLabel 1,3,x0,jcampCatalog SetDimLabel 1,4,dx,jcampCatalog else InsertPoints /M=0 numRows, 1, jcampCatalog endif End Function AddToCatalog(title, dataStartLine, dataEndLine, x0, dx, jcampCatalog) String title int dataStartLine, dataEndLine double x0, dx WAVE/T jcampCatalog if (strlen(title) == 0) Print "Spectrum missing ##TITLE label" return -1 endif if (numtype(dataStartLine) != 0) Print "Spectrum missing ##XYDATA label" return -1 endif if (numtype(dataEndLine) != 0) Print "Spectrum missing ##END label" return -1 endif if (numtype(x0) != 0) Print "Spectrum missing ##FIRSTX label" return -1 endif if (numtype(dx) != 0) Print "Spectrum missing ##DELTAX label" return -1 endif int row = DimSize(jcampCatalog,0) PrepareJCAMPCatalogForNewRow(jcampCatalog) jcampCatalog[row][%title] = title jcampCatalog[row][%startLine] = num2istr(dataStartLine) jcampCatalog[row][%endLine] = num2istr(dataEndLine) jcampCatalog[row][%x0] = num2str(x0) jcampCatalog[row][%dx] = num2str(dx) return 0 End Function/WAVE MakeJCAMPCatalog(pathName, filePath) String pathName // Name of symbolic path or "" to display dialog. String filePath // Name of file or "" to display dialog. Can also be full or partial path relative to symbolic path. Variable refNum Open/R/P=$pathName refNum as filePath String title="" int dataStartLine=-1, dataEndLine=-1 double x0=NaN, dx=NaN Make/FREE/T/N=0 jcampCatalog int spectrumNumber = 0 int lineNum = 0 do String text FReadLine refNum, text if (strlen(text) == 0) break endif String format if (strsearch(text,"##TITLE",0) == 0) title = replaceString("##TITLE= ", text, "") endif if (strsearch(text,"##FIRSTX",0) == 0) format = "##FIRSTX= %g" sscanf text, format, x0 endif if (strsearch(text,"##DELTAX",0) == 0) format = "##DELTAX= %g" sscanf text, format, dx endif if (strsearch(text,"##XYDATA",0) == 0) dataStartLine = lineNum + 1 endif if (strsearch(text,"##END",0) == 0) dataEndLine = lineNum - 1 if (AddToCatalog(title, dataStartLine, dataEndLine, x0, dx, jcampCatalog) != 0) break endif spectrumNumber += 1 title="" dataStartLine=-1; dataEndLine=-1 x0=NaN; dx=NaN endif lineNum += 1 while(1) Close refNum return jcampCatalog End Function/WAVE LoadJCAMPSpectrum(pathName, filePath, title, dataStartLine, dataEndLine, x0, dx) String pathName // Name of symbolic path or "" to display dialog. String filePath // Name of file or "" to display dialog. Can also be full or partial path relative to symbolic path. String title int dataStartLine, dataEndLine double x0, dx String name = title name = CleanupName(name, 0) String columnInfoStr sprintf columnInfoStr, "N='_skip_';N='%s';", name + "_Abs_Int" // Skip X wave to load Y wave int numDataLines = dataEndLine - dataStartLine + 1 LoadWave/G/D/A/B=columnInfoStr/P=$pathName/O/Q/L={0,dataStartLine,numDataLines,0,0} filePath sprintf columnInfoStr, "N='%s';N='_skip_';", name + "_Abs_WL" // Skip y wave to load X wave LoadWave/G/D/A/B=columnInfoStr/P=$pathName/O/Q/L={0,dataStartLine,numDataLines,0,0} filePath WAVE w = $name + "_Abs_Int" WAVE w1 = $name + "_Abs_WL" // Create wave reference return w End static Function AddWaveToList(jcampWaves, w) WAVE/WAVE jcampWaves WAVE w int index = DimSize(jcampWaves,0) Redimension/N=(index+1) jcampWaves jcampWaves[index] = w End Function AbsUpload(pathName, filePath) String pathName // Name of symbolic path or "" to display dialog. String filePath // Name of file or "" to display dialog. Can also be full or partial path relative to symbolic path. Variable refNum // Possibly display Open File dialog. if ((strlen(pathName)==0) || (strlen(filePath)==0)) String fileFilters = "Text Files (*.txt,*.dat):.txt,.dat;" fileFilters += "All Files:.*;" Open /D /R /P=$pathName /F=fileFilters refNum as filePath filePath = S_fileName // S_fileName is set by Open/D if (strlen(filePath) == 0) // User cancelled? return -1 endif // filePath is now a full path to the file. endif WAVE/T jcampCatalog = MakeJCAMPCatalog(pathName, filePath) // Returns a free wave Make/WAVE/FREE/N=0 jcampWaves int numSpectra = DimSize(jcampCatalog,0) int spectrumNumber = 0 do String title = jcampCatalog[spectrumNumber][%title] int dataStartLine = str2num(jcampCatalog[spectrumNumber][%startLine]) int dataEndLine = str2num(jcampCatalog[spectrumNumber][%endLine]) double x0 = str2num(jcampCatalog[spectrumNumber][%x0]) double dx = str2num(jcampCatalog[spectrumNumber][%dx]) WAVE w = LoadJCAMPSpectrum(pathName, filePath, title, dataStartLine, dataEndLine, x0, dx) AddWaveToList(jcampWaves, w) spectrumNumber += 1 while(spectrumNumber < numSpectra) return 0 End
