Graph marker size legend
Snippet to make a basic legend if the size of graph markers is used to display an additional parameter in xy plots, see macro examples() below.
function MarkerSizeLegend(string grName, string trName, int nPoints, variable YminFrac, variable YmaxFrac, variable Xfrac) // grName: Gaph name or "" for top window // trName: Trace name (e.g. w or w#1), NOT a wave name string // nPoints: number of markers for the legend // YminFrac, YmaxFrac: min and max of relative vertical plot area to be used for legend // Xfrac: x position of legend as relative plot area // get zmrk-info from trace of interest string trInfo = TraceInfo(grName, trName, 0) if(strlen(trInfo) == 0) print "Trace not found!" return 0 endif // get marker size info string S_info = StringbyKey("zmrkSize(x)", trInfo, "=") // get content in-between {} string SizePara SplitString/E="\{([^}]*)\}" s_info, SizePara // sizePara contains 5 elements string sW_Size = StringFromList(0, SizePara, ",") string sMinVal = StringFromList(1, SizePara, ",") string sMaxVal = StringFromList(2, SizePara, ",") string sMinMrkSize = StringFromList(3, SizePara, ",") string sMaxMrkSize = StringFromList(4, SizePara, ",") // get basic maker shape parameters string sMode = StringbyKey("mode(x)", trInfo, "=") string sMarker = StringbyKey("marker(x)", trInfo, "=") string sMrkThick = StringbyKey("mrkThick(x)", trInfo, "=") string sStroke = StringbyKey("useMrkStrokeRGB(x)", trInfo, "=") string sRgb = StringbyKey("rgb(x)", trInfo, "=") // is size wave multidimensional? variable isMD = stringmatch(sW_size, "*[*") if(isMD) string name, xRow, yCol // split e.g. wave0[*][2] or wave0[*][%zData] into wave name, row and column info splitstring/E="(.*?)\[(.*?)\]\[(.*?)\]" sW_size, name, xRow, yCol wave w = $name // now find column or row that contains size scaling // xRow can be a number or a DimLabel with preceeding % variable DimLabelCheck, SizeCol, SizeRow if(cmpstr(xRow, "*")==0) DimLabelCheck = strsearch(yCol,"%",0) SizeCol = DimLabelCheck == -1 ? str2Num(yCol) : FindDimLabel(w, 1, yCol[1,inf]) MatrixOP/FREE W_Size = col(w, SizeCol) elseif(cmpstr(yCol, "*")==0) DimLabelCheck = strsearch(xRow,"%",0) SizeRow = DimLabelCheck == -1 ? str2Num(xRow) : FindDimLabel(w, 0, xRow[1,inf]) MatrixOP/FREE W_Size = row(w, SizeRow) else return 0 endif else wave W_Size = $sW_size endif // what are the min/max values that markers are scaled against? variable MarkerMinVal, MarkerMaxVal if(cmpstr(sMinVal, "*")==0) MarkerMinVal = WaveMin(W_size) else MarkerMinVal = str2num(sMinval) endif if(cmpstr(sMaxVal, "*")==0) MarkerMaxVal = WaveMax(W_size) else MarkerMaxVal = str2num(sMaxval) endif // make marker legend wave with nPoints scaled to min/max values Make/O/N=(nPoints, 2) M_mrkSize = 0 SetDimlabel 1, 0, relSize, M_mrkSize SetDimlabel 1, 1, Pos, M_mrkSize Setscale/I x MarkerMinVal, MarkerMaxVal, M_mrkSize M_mrkSize[][%relSize] = x // append to top graph, first remove if present RemoveFromGraph/Z M_mrkSize AppendToGraph/R=R_mSize/B=B_mSize M_mrkSize[][%relSize] vs M_mrkSize[][%Pos] // set new right axis ModifyGraph axisEnab(R_mSize)= {YminFrac,YmaxFrac} ModifyGraph freePos(R_mSize)={1-xFrac,kwFraction} ModifyGraph tick(R_mSize)=2,btLen(R_mSize)=3 SetAxis/A/N=1 R_mSize // set new bottom axis ModifyGraph axisEnab(B_mSize)={xFrac-0.1,xFrac} ModifyGraph freePos(B_mSize)={yMinFrac,kwFraction} ModifyGraph noLabel(B_mSize)=2, tick(B_mSize)=3, axThick(B_mSize)=0 // apply marker parameters string mrkPara sprintf mrkPara, "ModifyGraph mode(M_mrkSize)=%s,marker(M_mrkSize)=%s,mrkThick(M_mrkSize)=%s,useMrkStrokeRGB(M_mrkSize)=%s, rgb(M_mrkSize)=%s", sMode, sMarker, sMrkThick, sStroke, sRgb Execute/Z mrkPara // then update size parameters string zmrkStr sprintf zmrkStr, "ModifyGraph zmrkSize(M_mrkSize)={M_mrkSize[*][0], %s, %s, %s, %s}", sMinVal, sMaxVal, sMinMrkSize, sMaxMrkSize Execute/Z zmrkStr end macro examples() Make/O/N=40 xx=p+enoise(0.1*p), yy=p+enoise(0.1*p), zz= 10*gauss(p, 20, 10) // 1: set of 1d waves Display yy vs xx ModifyGraph mode=3,marker=19,useMrkStrokeRGB=1 ModifyGraph zmrkSize(yy)={zz,*,*,2,10} MarkerSizeLegend("", "yy", 5, 0.1, 0.5, 0.9) // 2: single 2d wave with dimlabels Concatenate/O/DL {xx,yy,zz}, data Display data[][%yy] vs data[][%xx] ModifyGraph mode=3,marker=19,useMrkStrokeRGB=1 ModifyGraph zmrkSize(data)={data[*][%zz],*,*,2,10} MarkerSizeLegend("", "data", 5, 0.5, 0.9, 0.15) endMacro
