Fake Waterfall Plot
hrodstein
// Igor can display waterfall plots using the NewWaterfall operation (choose Windows->New->Packages->Waterfall Plot). // This requires storing your data in a 2D wave. You can also create a 3D waterfall plot using Gizmo. // // However, for the common case of displaying a series of spectra, you may find that a "fake waterfall plot" // is more convenient. And it works with your original waveform or XY data. // // A fake waterfall plot is a regular graph with multiple waveform or XY traces where you use Igor's X and Y // trace display offset feature to create the waterfall effect. This is simple and also gives you a regular // Igor graph with regular traces that you can format and annotate using familiar techniques. // // Here is a procedure for converting a regular graph with multiple waveform or XY traces into a fake waterfall plot. // The ApplyFakeWaterfall function converts a regular graph to a fake waterfall plot. // The RemoveFakeWaterfall function converts it back to a regular graph. // // The attached experiment file contains these procedures along with sample data and a sample graph. Function ApplyFakeWaterfall(graphName, dx, dy, hidden) // e.g., ApplyFakeWaterfall("Graph0", 2, 100, 1) String graphName // Name of graph or "" for top graph Variable dx, dy // Used to offset traces to create waterfall effect Variable hidden // If true, apply hidden line removal String traceList = TraceNameList(graphName, ";", 1) Variable numberOfTraces = ItemsInLIst(traceList) Variable traceNumber for(traceNumber=0; traceNumber<numberOfTraces; traceNumber+=1) String trace = StringFromList(traceNumber, traceList) Variable offsetX = (numberOfTraces-traceNumber-1) * dx Variable offsetY = (numberOfTraces-traceNumber-1) * dy ModifyGraph/W=$graphName offset($trace)={offsetX,offsetY} ModifyGraph/W=$graphName plusRGB($trace)=(65535,65535,65535) // Fill color is white if (hidden) ModifyGraph/W=$graphName mode($trace)=7, hbFill($trace)=1 // Fill to zero, erase mode else ModifyGraph/W=$graphName mode($trace)=0 // Lines between points endif endfor End Function RemoveFakeWaterfall(graphName) // e.g., RemoveFakeWaterfall("Graph0") String graphName // Name of graph or "" for top graph String traceList = TraceNameList(graphName, ";", 1) Variable numberOfTraces = ItemsInLIst(traceList) Variable traceNumber for(traceNumber=0; traceNumber<numberOfTraces; traceNumber+=1) String trace = StringFromList(traceNumber, traceList) ModifyGraph/W=$graphName offset($trace)={0,0} ModifyGraph/W=$graphName plusRGB($trace)=(65535,65535,65535) // Fill color is white ModifyGraph/W=$graphName mode($trace)=0 // Lines between points endfor End
