Extracting compressed archives from within Igor Pro using the CallFunction XOP and libarchive
The following Igor Pro code uses the CallFunction XOP to uncompress zip and tar files.
#pragma TextEncoding = "UTF-8" #pragma rtGlobals=3 // Use modern global access method and strict wave access. #include "FCALL_functions" /// This example shows how the CallFunction-XOP is used to extract an archive. /// /// The libarchive library is used for extraction (https://github.com/libarchive/libarchive) /// /// How to run this example: /// - have some tar or zip archive file ready you want to decompress. /// (The archive.dll for this example is compiled with zip and tar support only.) /// /// - Run UncompressFiles(archiveName, targetPath) -- e.g. UncompressFiles("C:\\archive\\data.zip", "C:\\analysis") static StrConstant UCF_LIBARCHIVE_DLL = "archive.dll" static StrConstant UCF_ARCHIVE_ENTRYPTR = "root:arcEntry" static StrConstant UCF_ARCHIVE_BUFFERPTR = "root:arcBuffer" static StrConstant UCF_ARCHIVE_SIZETR = "root:arcSize" static StrConstant UCF_ARCHIVE_OFFSETPTR = "root:arcOffset" static Constant UCF_ARCHIVE_BLOCKSIZE = 10240 static Constant ARCHIVE_EXTRACT_TIME = 0x0004 static Constant ARCHIVE_EXTRACT_PERM = 0x0002 static Constant ARCHIVE_EXTRACT_ACL = 0x0020 static Constant ARCHIVE_EXTRACT_FFLAGS = 0x0040 static Constant ARCHIVE_OK = 0 static Constant ARCHIVE_EOF = 1 static Constant ARCHIVE_WARN = -20 /// @brief Extracts an archive to a target path /// @param[in] arcFileName full file path to the archive file /// @param[in] targetPath file path to the location where the archive is decompressed, use "" for current path of Igor process /// @returns NaN on error, 0 otherwise Function UncompressFiles(arcFileName, targetPath) string arcFileName, targetPath string libHandle string dllPath, functionName, entryPath, entryTarget variable numItems, result UInt64 archiveRead, archiveWrite Int64 entrySize string reflectedProcpath = FunctionPath("UncompressFiles") numItems = ItemsInList(reflectedProcpath, ":") if(!numItems) return NaN endif reflectedProcpath = RemoveListItem(numItems - 1, reflectedProcpath, ":") dllPath = reflectedProcpath + UCF_LIBARCHIVE_DLL if(!IsEmpty(targetPath)) targetPath = ParseFilepath(5, targetPath, "\\", 0, 0) targetPath = ParseFilepath(2, targetPath, "\\", 0, 0) endif UCF_CreateFunctionTemplates() Make/O/L/U/N=1 $UCF_ARCHIVE_ENTRYPTR, $UCF_ARCHIVE_BUFFERPTR, $UCF_ARCHIVE_SIZETR Make/O/L/N=1 $UCF_ARCHIVE_OFFSETPTR libHandle = FCALL_Load(dllPath) [archiveRead] = UCF_archive_read_new(libHandle) UCF_archive_read_support_format_all(libHandle, archiveRead) UCF_archive_read_support_compression_all(libHandle, archiveRead) [archiveWrite] = UCF_archive_write_disk_new(libHandle) UCF_archive_write_disk_set_options(libHandle, archiveWrite, ARCHIVE_EXTRACT_TIME | ARCHIVE_EXTRACT_PERM | ARCHIVE_EXTRACT_ACL | ARCHIVE_EXTRACT_FFLAGS) UCF_archive_write_disk_set_standard_lookup(libHandle, archiveWrite) result = UCF_archive_read_open_filename(libHandle, archiveRead, arcFileName, UCF_ARCHIVE_BLOCKSIZE) if(result != ARCHIVE_OK) printf "Error %d on open file %s\r", result, arcFileName FCALL_Free(libHandle) return NaN endif for(;;) result = UCF_archive_read_next_header(libHandle, archiveRead, UCF_ARCHIVE_ENTRYPTR) if(result == ARCHIVE_EOF) break endif if(result < ARCHIVE_OK) print "error: " + UCF_archive_error_string(libHandle, archiveRead) endif if(result < ARCHIVE_WARN) FCALL_Free(libHandle) return NaN endif WAVE entry = $UCF_ARCHIVE_ENTRYPTR entryPath = UCF_archive_entry_pathname(libHandle, entry[0]) entryTarget = UCF_FormatFilePath(targetPath + entryPath) printf "%s ", ReplaceString("\\\\", entryTarget, "\\") UCF_archive_entry_set_pathname(libHandle, entry[0], entryTarget) result = UCF_archive_write_header(libHandle, archiveWrite, entry[0]) if(result < ARCHIVE_OK) print "error: " + UCF_archive_error_string(libHandle, archiveWrite) else [entrySize] = UCF_archive_entry_size(libHandle, entry[0]) result = copy_data(libHandle, archiveRead, archiveWrite, entrySize) if(result < ARCHIVE_WARN) FCALL_Free(libHandle) return NaN endif endif result = UCF_archive_write_finish_entry(libHandle, archiveWrite) if(result < ARCHIVE_OK) print "error: " + UCF_archive_error_string(libHandle, archiveRead) endif if(result < ARCHIVE_WARN) FCALL_Free(libHandle) return NaN endif printf "\r" endfor UCF_archive_read_close(libHandle, archiveRead) UCF_archive_read_free(libHandle, archiveRead) UCF_archive_write_close(libHandle, archiveWrite) UCF_archive_write_free(libHandle, archiveWrite) FCALL_Free(libHandle) return 0 End /// @brief Copy data for one archived file from the archive to the unpacked file /// Show some basic progress. static Function copy_data(String libHandle, UInt64 arcread, UInt64 arcWrite, Int64 entrySize) variable result, perc, oldperc string dots WAVE buffer = $UCF_ARCHIVE_BUFFERPTR WAVE size = $UCF_ARCHIVE_SIZETR WAVE offset = $UCF_ARCHIVE_OFFSETPTR printf "[" for(;;) result = UCF_archive_read_data_block(libHandle, arcread, UCF_ARCHIVE_BUFFERPTR, UCF_ARCHIVE_SIZETR, UCF_ARCHIVE_OFFSETPTR) if(result == ARCHIVE_EOF) dots = PadString("", 100 - oldperc, char2num(".")) printf dots + "]" return ARCHIVE_OK endif if(result < ARCHIVE_OK) print "error: " + UCF_archive_error_string(libHandle, arcread) return result endif result = UCF_archive_write_data_block(libHandle, arcWrite, buffer[0], size[0], offset[0]) if(result < ARCHIVE_OK) print "error: " + UCF_archive_error_string(libHandle, arcWrite) return result endif if(entrySize) perc = trunc(offset[0] * 100 / entrySize) if(perc != oldperc) dots = PadString("", perc - oldperc, char2num(".")) printf dots oldperc = perc DoUpdate endif endif endfor End /// Function wrappers for the library calls static Function [UInt64 arcHandle] UCF_archive_read_new(String libHandle) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_read_new" jsonID = jsonIDList[%$(funcName)] [arcHandle] = UCF_ParseResultToUInt64(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) return [arcHandle] End static Function UCF_archive_read_support_format_all(String libHandle, UInt64 arcHandle) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_read_support_format_all" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_Release(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function UCF_archive_read_support_compression_all(String libHandle, UInt64 arcHandle) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_read_support_compression_all" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_Release(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function [UInt64 arcHandle] UCF_archive_write_disk_new(String libHandle) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_write_disk_new" jsonID = jsonIDList[%$(funcName)] [arcHandle] = UCF_ParseResultToUInt64(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) return [arcHandle] End static Function UCF_archive_write_disk_set_options(String libHandle, UInt64 arcHandle, Variable flags) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_write_disk_set_options" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_SetVariable(jsonID, "/Parameter/1/value", flags) JSON_Release(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function UCF_archive_write_disk_set_standard_lookup(String libHandle, UInt64 arcHandle) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_write_disk_set_standard_lookup" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_Release(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function UCF_archive_read_open_filename(String libHandle, UInt64 arcHandle, String fileName, Variable blockSize) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_read_open_filename" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_SetString(jsonID, "/Parameter/1/value", fileName) JSON_SetVariable(jsonID, "/Parameter/2/value", blockSize) return UCF_ParseResultToNumber(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function UCF_archive_read_next_header(String libHandle, UInt64 arcHandle, String entryPtr) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_read_next_header" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_SetString(jsonID, "/Parameter/1/value", entryPtr) return UCF_ParseResultToNumber(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function/S UCF_archive_error_string(String libHandle, UInt64 arcHandle) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_error_string" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) return UCF_ParseResultToString(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function UCF_archive_write_header(String libHandle, UInt64 arcHandle, UInt64 entry) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_write_header" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_SetUInt64(jsonID, "/Parameter/1/value", entry) return UCF_ParseResultToNumber(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function [Int64 entrySize] UCF_archive_entry_size(String libHandle, UInt64 arcEntry) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_entry_size" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcEntry) [entrySize] = UCF_ParseResultToInt64(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) return [entrySize] End static Function UCF_archive_read_data_block(String libHandle, UInt64 arcHandle, String bufferPtr, String sizePtr, String offsetPtr) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_read_data_block" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_SetString(jsonID, "/Parameter/1/value", bufferPtr) JSON_SetString(jsonID, "/Parameter/2/value", sizePtr) JSON_SetString(jsonID, "/Parameter/3/value", offsetPtr) return UCF_ParseResultToNumber(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function UCF_archive_write_data_block(String libHandle, UInt64 arcHandle, UInt64 buffer, UInt64 size, Int64 offset) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_write_data_block" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_SetUInt64(jsonID, "/Parameter/1/value", buffer) JSON_SetUInt64(jsonID, "/Parameter/2/value", size) JSON_SetInt64(jsonID, "/Parameter/3/value", offset) return UCF_ParseResultToNumber(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function UCF_archive_write_finish_entry(String libHandle, UInt64 arcHandle) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_write_finish_entry" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) return UCF_ParseResultToNumber(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function UCF_archive_read_close(String libHandle, UInt64 arcHandle) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_read_close" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_Release(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function UCF_archive_read_free(String libHandle, UInt64 arcHandle) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_read_free" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_Release(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function/S UCF_archive_write_close(String libHandle, UInt64 arcHandle) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_write_close" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_Release(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function/S UCF_archive_write_free(String libHandle, UInt64 arcHandle) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_write_free" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcHandle) JSON_Release(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function/S UCF_archive_entry_pathname(String libHandle, UInt64 arcEntry) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_entry_pathname" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcEntry) return UCF_ParseResultToString(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End static Function UCF_archive_entry_set_pathname(String libHandle, UInt64 arcEntry, String pathName) variable jsonID WAVE jsonIDList WAVE/T functionNameList string funcName = "archive_entry_set_pathname" jsonID = jsonIDList[%$(funcName)] JSON_SetUInt64(jsonID, "/Parameter/0/value", arcEntry) JSON_SetString(jsonID, "/Parameter/1/value", pathName) JSON_Release(FCALL_Call(libHandle, functionNameList[%$(funcName)], jsonID)) End /// Various support functions static Function/S UCF_FormatFilePath(fPath) string fPath string winFilePath = ParseFilepath(5, fPath, "\\", 0, 0) return ReplaceString("\\", winFilePath, "\\\\") End static Function UCF_ParseResultToNumber(Variable jsonID) variable result = JSON_GetVariable(jsonID, "/result/value") JSON_Release(jsonID) return result End static Function/S UCF_ParseResultToString(Variable jsonID) string result = JSON_GetString(jsonID, "/result/value") JSON_Release(jsonID) return result End static Function [Int64 result] UCF_ParseResultToInt64(Variable jsonID) [result] = JSON_GetInt64(jsonID, "/result/value") JSON_Release(jsonID) return [result] End static Function [UInt64 result] UCF_ParseResultToUInt64(Variable jsonID) [result] = JSON_GetUInt64(jsonID, "/result/value") JSON_Release(jsonID) return [result] End threadsafe static Function IsEmpty(str) string& str variable len = strlen(str) return numtype(len) == 2 || len <= 0 End /// @brief Creates a json template for a specific library function /// The templates are later used in the wrapper function that execute the call to the library static Function UCF_AddFunctionTemplate(functionName, paramList, [callFunctionName]) string functionName, paramList, callFunctionName WAVE jsonIDList WAVE/T functionNameList variable size size = DimSize(jsonIDList, 0) Redimension/N=(size + 1) jsonIDList, functionNameList functionNameList[size] = SelectString(ParamIsDefault(callFunctionName), callFunctionName, functionName) jsonIDList[size] = FCALL_SetupParameterIn(paramList) SetDimLabel 0, size, $functionName, jsonIDList, functionNameList End /// @brief Creates json templates for libarchive functions static Function UCF_CreateFunctionTemplates() Make/O/D/N=(0) jsonIDList Make/O/T/N=(0) functionNameList // archive_read_new UCF_AddFunctionTemplate("archive_read_new", "UINT64") // archive_read_support_format_all UCF_AddFunctionTemplate("archive_read_support_format_all", "INT32;UINT64") // archive_read_support_compression_all UCF_AddFunctionTemplate("archive_read_support_compression_all", "INT32;UINT64") // archive_write_disk_new UCF_AddFunctionTemplate("archive_write_disk_new", "UINT64") // archive_write_disk_set_options UCF_AddFunctionTemplate("archive_write_disk_set_options", "INT32;UINT64;INT32") // archive_write_disk_set_standard_lookup UCF_AddFunctionTemplate("archive_write_disk_set_standard_lookup", "INT32;UINT64") // archive_read_open_filename UCF_AddFunctionTemplate("archive_read_open_filename", "INT32;UINT64;STRING;UINT64") // archive_read_next_header UCF_AddFunctionTemplate("archive_read_next_header", "INT32;UINT64;WAVEREF") // archive_error_string UCF_AddFunctionTemplate("archive_error_string", "STRING;UINT64") // archive_write_header UCF_AddFunctionTemplate("archive_write_header", "INT32;UINT64;UINT64") // archive_entry_size UCF_AddFunctionTemplate("archive_entry_size", "INT32;UINT64") // archive_read_data_block UCF_AddFunctionTemplate("archive_read_data_block", "INT32;UINT64;WAVEREF;WAVEREF;WAVEREF") // archive_write_data_block UCF_AddFunctionTemplate("archive_write_data_block", "INT32;UINT64;UINT64;UINT64;INT64") // archive_write_finish_entry UCF_AddFunctionTemplate("archive_write_finish_entry", "INT32;UINT64") // archive_read_close UCF_AddFunctionTemplate("archive_read_close", "INT32;UINT64") // archive_read_free UCF_AddFunctionTemplate("archive_read_free", "INT32;UINT64") // archive_write_close UCF_AddFunctionTemplate("archive_write_close", "INT32;UINT64") // archive_write_free UCF_AddFunctionTemplate("archive_write_free", "INT32;UINT64") // archive_entry_pathname UCF_AddFunctionTemplate("archive_entry_pathname", "STRING;UINT64") // archive_entry_set_pathname UCF_AddFunctionTemplate("archive_entry_set_pathname", "INT32;UINT64;STRING") End
