Exterminate Wave
Exterminate Wave removes (kills) a wave from the experiment even if it is displayed in tables or graphs (images & contours included). Needs IP Version > 6.20. May treat subwindows improperly (not thoroughly checked).
function ExterminateWave(w)
wave w
    variable retVal = 0
    if( WaveExists(w) )
        RemoveWaveFormAllWindows(w)
        CheckDisplayed /A w // successfully removed (e.g. subwindows not treated yet) ?
        if( V_Flag )
            retVal = -1     // code for "in use in windows"
        try                 // this may fail since do not treat user functions (yet)
            KillWaves w // no /Z flag, since that does not generate a V_Flag return value
        catch               // but any user of this function really wants to know if it did not work
            retVal = -2     // code for "in use in functions"
        endtry
    return retVal
function RemoveWaveFormAllWindows(w)
wave w
    CheckDisplayed /A w
    if( V_Flag )
        RemoveWaveFromAllGraphs(w)
        RemoveWaveFromAllTables(w)
function RemoveWaveFromAllGraphs(w)
wave w
    string graphList = WindowsUsingWave(w, 1)
    variable k
    for( k = 0; k < ItemsInList(graphList); k += 1 )
        RemoveWaveFromGraph(StringFromList(k, graphList), w, -1)
function RemoveWaveFromAllTables(w)
wave w
    string table, tableList = WindowsUsingWave(w, 2)
    variable numCols, oldCols, k
    for( k = 0; k < ItemsInList(tableList); k += 1 )
        table = StringFromList(k, tableList)
        numCols = NumberByKey("COLUMNS", TableInfo(table, -2))
        do
            oldCols = numCols
            RemoveFromTable /W=$table w     // RemoveFromTable is not picky about column specs...
        while( oldCols > numCols )
        if( numCols == 0 )
            DoWindow /K $table
function/S WindowsUsingWave(w, windowtype)
wave w
variable windowtype
    string win, wins = WinList("*", ";", "WIN:"+num2str(windowtype))    // should be modified to include subwindows
    string result = ""
    variable k
    for( k = 0; k < ItemsInList(wins); k += 1 )
        win = StringFromList(k, wins)
        CheckDisplayed /W=$win w    // this may not be the best way...
        if( V_Flag )
            result = AddListItem(win, result)
    return result
function RemoveWaveFromGraph(graph, w, options)
string graph
wave w
variable options // bit-wise: 1=waves, 2=contours, 4=images; pass -1 for "all"
    string wavPath = GetWavesDataFolder(w, 2)   // full path of data folder, including possibly quoted wave name
    string allObjects = ""
    string instanceList, instance, objPath, xwavePath
    variable k
    if( options & 1 )   // traces
        instanceList = TraceNameList(graph, ";", 1)
        allObjects += instanceList
        for( k = ItemsInList(instanceList); k > 0 ; k -= 1 )        // need backward loop since ...
            instance = StringFromList(k-1, instanceList)
            objPath = GetWavesDataFolder(TraceNameToWaveRef(graph, instance), 2)
            wave xwave = XWaveRefFromTrace(graph, instance)
            if( WaveExists(xwave) )
                xwavePath = GetWavesDataFolder(xwave, 2)
                xwavePath = ""
            if( !cmpstr(wavPath, objPath) || !cmpstr(wavPath, xwavePath) )
                RemoveFromGraph /W=$graph $instance // ... this changes instance numbers
                allObjects = RemoveFromList(instance, allObjects)
    if( options & 2 )   // contours
        instanceList = ContourNameList(graph, ";")
            objPath = GetWavesDataFolder(ContourNameToWaveRef(graph, instance), 2)
            if( !cmpstr(wavPath, objPath) )
                RemoveContour /W=$graph $instance       // ... this changes instance numbers
    if( options & 4 )   // images
        instanceList = ImageNameList(graph, ";")
            objPath = GetWavesDataFolder(ImageNameToWaveRef(graph, instance), 2)
                RemoveImage /W=$graph $instance     // ... this changes instance numbers
    if( ItemsInList(allObjects) == 0 )
        DoWindow /K $graph
