DataBrowser Folder Versioning Button
// This installs or removes a VersionFolder button in the DataBrowser
// The VersionFolder button will create a duplicate of the currently selected data folder
// with a date+time stamp appended to it:  'folder name'YYMMDDHHSS
// Copy this to the procedure window, compile, open a Data Browser,
// and then type InstallVersions() on the command line
// Select a data folder to version and click the VersionFolder button
// Remove the button by typing RemoveVersions() at the command line
// This also works with multiple data folders selected ... it will parse and run the command on each one
// It may choke on data folders with long names!
#pragma rtGlobals=1
Function InstallVersions()
	Execute/P/Q/Z "ModifyBrowser appendUserButton={VersionFolder,\"StoreFolderVersion(%s)\"}"
Function RemoveVersions()
	Execute/Q/Z "ModifyBrowser deleteUserButton=VersionFolder"
Function StoreFolderVersion(df)
	DFREF df
        // return if this is not a data folder
	if (DataFolderRefStatus(df)==0)
	// uncomment this next portion if you would like to avoid versioning the Packages data folder
//	if (DataFolderRefsEqual(df,root:Packages))
//		return 0
//	endif
        // get information about the data folder
	string cdf = ParseFilePath(1,GetDataFolder(1,df),":",1,0)
	string sdf = ReplaceString("'",GetDataFolder(0,df),"")
        // create the new data folder name
	string currDTS, vdf
	sprintf currDTS, "%s%s",secs2date(DateTime,-2,":")[2,9],secs2time(DateTime,2)
	sprintf currDTS "%s%s" sdf, ReplaceString("'",ReplaceString(":",currDTS,""),"")
	sprintf vdf, "%s%s", cdf, PossiblyQuoteName(currDTS)
        // if the new already exists, do not overwrite
	if (DataFolderExists(vdf))
       // make the new data folder
	DuplicateDataFolder df, $vdf
