Cropped ternary diagram template
Snippet to generate a ternary diagram template. The ternary can be "full" or cropped, such that the top corner can be truncated at fractional values from 0.3 to 0.7 (in 0.1 increments). Cropping below or above that doesn't make much sense to me, but it could easily be added.
The function ConvMatrix2Ternary(M_Data) converts a 3-column data matrix in to a 2-column converted matrix that is compatible with ternary coordinates.
EDIT Jan 22nd 2019:
The initial code below contained a bug: The diagram coordinates and grid points need to be converted by multiplying the values of M_TernaryTemplate with cos(30*pi/180) and not, as initially posted, by dividing it. This has been fixed below. Sorry for any inconvenience.
function MakeTernaryTemplate([variable crop])
    // was crop specified? If not, default is the full ternary
    crop = ParamIsDefault(crop) ? 10 : Crop*10
    // aspect ratio of the ternary plot
    variable aspectRatio
    switch(crop)
        case 10 :
            Make/D/O/N=(37,4) M_TernaryTemplate = NaN
            M_TernaryTemplate[0][0]= {0,1,0.5,0}
            M_TernaryTemplate[0][1]= {0,0,1,0}
            M_TernaryTemplate[0][2]= {0.05,0.1,0.55,0.45,0.9,0.95,0.05,NaN,0.1,0.2,0.2,0.6,0.4,0.8,0.9,0.1,NaN,0.15,0.3,0.65,0.35,0.7,0.85,0.15,NaN,0.2,0.4,0.7,0.3,0.6,0.8,0.2,NaN,0.25,0.5,0.75,0.25}
            M_TernaryTemplate[0][3]= {0.1,0,0.9,0.9,0,0.1,0.1,NaN,0.2,0,0,0.8,0.8,0,0.2,0.2,NaN,0.3,0,0.7,0.7,0,0.3,0.3,NaN,0.4,0,0.6,0.6,0,0.4,0.4,NaN,0.5,0,0.5,0.5}
            aspectRatio = 1.25
            break
        case 3 :
            Make/D/O/N=(44,4) M_TernaryTemplate = NaN
            M_TernaryTemplate[0][0]= {0,1,0.85,0.15,0}
            M_TernaryTemplate[0][1]= {0,0,0.3,0.3,0}
            M_TernaryTemplate[0][2]= {0.05,0.95,NaN,0.1,0.9,NaN,0.15,0.85,NaN,0.05,0.1,0.25,NaN,0.1,0.2,0.35,NaN,0.15,0.3,0.45,NaN,0.25,0.4,0.55,NaN,0.35,0.5,0.65,NaN,0.45,0.6,0.75,NaN,0.55,0.7,0.85,NaN,0.65,0.8,0.9,NaN,0.75,0.9,0.95}
            M_TernaryTemplate[0][3]= {0.1,0.1,NaN,0.2,0.2,NaN,0.3,0.3,NaN,0.1,0,0.3,NaN,0.2,0,0.3,NaN,0.3,0,0.3,NaN,0.3,0,0.3,NaN,0.3,0,0.3,NaN,0.3,0,0.3,NaN,0.3,0,0.3,NaN,0.3,0,0.2,NaN,0.3,0,0.1}
            aspectRatio = 3
            break
        case 4 :
            Make/D/O/N=(47,4) M_TernaryTemplate = NaN
            M_TernaryTemplate[0][0]= {0,1,0.8,0.2,0}
            M_TernaryTemplate[0][1]= {0,0,0.4,0.4,0}
            M_TernaryTemplate[0][2]= {0.05,0.95,NaN,0.1,0.9,NaN,0.15,0.85,NaN,0.2,0.8,NaN,0.05,0.1,0.3,NaN,0.1,0.2,0.4,NaN,0.15,0.3,0.5,NaN,0.2,0.4,0.6,NaN,0.3,0.5,0.7,NaN,0.4,0.6,0.8,NaN,0.5,0.7,0.85,NaN,0.6,0.8,0.9,NaN,0.7,0.9,0.95}
            M_TernaryTemplate[0][3]= {0.1,0.1,NaN,0.2,0.2,NaN,0.3,0.3,NaN,0.4,0.4,NaN,0.1,0,0.4,NaN,0.2,0,0.4,NaN,0.3,0,0.4,NaN,0.4,0,0.4,NaN,0.4,0,0.4,NaN,0.4,0,0.4,NaN,0.4,0,0.3,NaN,0.4,0,0.2,NaN,0.4,0,0.1}
            aspectRatio = 2.85
            break
        case 5 :
            Make/D/O/N=(50,4) M_TernaryTemplate = NaN
            M_TernaryTemplate[0][0]= {0,1,0.75,0.25,0}
            M_TernaryTemplate[0][1]= {0,0,0.5,0.5,0}
            M_TernaryTemplate[0][2]= {0.05,0.95,NaN,0.1,0.9,NaN,0.15,0.85,NaN,0.2,0.8,NaN,0.25,0.75,NaN,0.05,0.1,0.35,NaN,0.1,0.2,0.45,NaN,0.15,0.3,0.55,NaN,0.2,0.4,0.65,NaN,0.25,0.5,0.75,NaN,0.35,0.6,0.8,NaN,0.45,0.7,0.85,NaN}
            M_TernaryTemplate[43][2]= {0.55,0.8,0.9,NaN,0.65,0.9,0.95}
            M_TernaryTemplate[0][3]= {0.1,0.1,NaN,0.2,0.2,NaN,0.3,0.3,NaN,0.4,0.4,NaN,0.5,0.5,NaN,0.1,0,0.5,NaN,0.2,0,0.5,NaN,0.3,0,0.5,NaN,0.4,0,0.5,NaN,0.5,0,0.5,NaN,0.5,0,0.4,NaN,0.5,0,0.3,NaN,0.5,0,0.2,NaN,0.5,0,0.1}
            aspectRatio = 2.5
            break
        case 6 :
            Make/D/O/N=(53,4) M_TernaryTemplate = NaN
            M_TernaryTemplate[0][0]= {0,1,0.7,0.3,0}
            M_TernaryTemplate[0][1]= {0,0,0.6,0.6,0}
            M_TernaryTemplate[0][2]= {0.05,0.95,NaN,0.1,0.9,NaN,0.15,0.85,NaN,0.2,0.8,NaN,0.25,0.75,NaN,0.3,0.7,NaN,0.05,0.1,0.4,NaN,0.1,0.2,0.5,NaN,0.15,0.3,0.6,NaN,0.2,0.4,0.7,NaN,0.25,0.5,0.75,NaN,0.3,0.6,0.8,NaN,0.4,0.7,0.85}
            M_TernaryTemplate[45][2]= {NaN,0.5,0.8,0.9,NaN,0.6,0.9,0.95}
            M_TernaryTemplate[0][3]= {0.1,0.1,NaN,0.2,0.2,NaN,0.3,0.3,NaN,0.4,0.4,NaN,0.5,0.5,NaN,0.6,0.6,NaN,0.1,0,0.6,NaN,0.2,0,0.6,NaN,0.3,0,0.6,NaN,0.4,0,0.6,NaN,0.5,0,0.5,NaN,0.6,0,0.4,NaN,0.6,0,0.3,NaN,0.6,0,0.2,NaN,0.6,0,0.1}
            aspectRatio = 2
            break
        case 7 :
            M_TernaryTemplate[0][0]= {0,1,0.65,0.35,0}
            M_TernaryTemplate[0][1]= {0,0,0.7,0.7,0}
            M_TernaryTemplate[0][2]= {0.05,0.95,NaN,0.1,0.9,NaN,0.15,0.85,NaN,0.2,0.8,NaN,0.25,0.75,NaN,0.3,0.7,NaN,0.05,0.1,0.45,NaN,0.1,0.2,0.55,NaN,0.15,0.3,0.65,NaN,0.2,0.4,0.7,NaN,0.25,0.5,0.75,NaN,0.3,0.6,0.8,NaN,0.35,0.7}
            M_TernaryTemplate[44][2]= {0.85,NaN,0.45,0.8,0.9,NaN,0.55,0.9,0.95}
            M_TernaryTemplate[0][3]= {0.1,0.1,NaN,0.2,0.2,NaN,0.3,0.3,NaN,0.4,0.4,NaN,0.5,0.5,NaN,0.6,0.6,NaN,0.1,0,0.7,NaN,0.2,0,0.7,NaN,0.3,0,0.7,NaN,0.4,0,0.6,NaN,0.5,0,0.5,NaN,0.6,0,0.4,NaN,0.7,0,0.3,NaN,0.7,0,0.2,NaN,0.7,0,0.1}
            aspectRatio = 1.75
            break
        default:
            DoAlert 0, "Sorry, that crop-value is not supported!"
            return -1
    endswitch
    // convert Y (columns 1 and 3) to ternary coordinates
    variable factor = cos(30*pi/180)
    M_ternaryTemplate[][1] *= factor
    M_ternaryTemplate[][3] *= factor
    // display ternary if it doesn't exist
    DoWindow/F Ternary
    if(!V_flag)
        Display/N=Ternary M_TernaryTemplate[][1] vs M_TernaryTemplate[][0]
        ModifyGraph noLabel=2,axThick=0, rgb=(0,0,0), lsize(M_TernaryTemplate)=2
        ModifyGraph margin=50
        // append grid
        AppendToGraph M_TernaryTemplate[][3] vs M_TernaryTemplate[][2]
        ModifyGraph rgb(M_TernaryTemplate#1)=(16385,28398,65535), lstyle(M_TernaryTemplate#1)=1
    ModifyGraph width={Aspect,aspectRatio}
    return 1
    // M_Data needs to be organised: left [][0], right [][1], top[][2] of the ternary
    wave M_Data
    // Make temp wave: normalise in case it isn't and/or turn to fractions
    Duplicate/O/FREE M_Data, M_temp
    MatrixOP/FREE W_Sum = sumRows(M_temp)
    M_temp = M_temp[p][q] / W_Sum[p]
    // make output wave M_XY
    Make/D/O/N=(DimSize(M_Data,0), 2) M_XY
    // Do transformation to ternary coordinates;
    // Then use: AppendToGraph M_xy[][1] vs M_xy[][0] to add to ternary template
    M_XY[][0] =      0.5 * M_temp[p][2] + M_temp[p][1]
    M_XY[][1] =  M_temp[p][2] * cos(30 * (pi/180))
Usage:
// make some data
Make/D/O/N=(19,3) M_Data
M_Data[0][0]= {62.9,51.5,60.1,63.5,44.6,56.8,43.3,74.1,0.3,1.2,52.4,66.1,63.3,54.1,73.3,0.3,0.3,89.7,88.5}
M_Data[0][1]= {34.5,45.3,36.8,34.4,52.4,41.8,50.2,19.6,69.8,54.1,40.1,29.8,32.9,39.4,20.9,65.6,45.2,4.1,5.4}
M_Data[0][2]= {2.6,3.2,3.1,2.1,3,1.4,2.3,1,15.1,14,1,1.4,1.6,2.4,0.8,15.9,30.5,4.8,4.2}
// convert data
// generate template
MakeTernaryTemplate(crop=0.5)
// append converted data
CroppedTernaryTemplate.ipf (5.99 KB)
