Create your own terminal window
This snippet exists with thanks to the suggestions from many people.
Normally one uses the Igor command line to call user defined functions and Igor+XOP Operations and functions. However, there is no way (AFAIK) of having a user defined operation from the command line. i.e. the user defined function must always be of the form "myfunc(arg1, arg2)" instead of "myop arg1 arg1".
Where this becomes interesting is when you are talking to something like a network server, or an acquisition device. Normally they have their own command set. One would wish to issue that command directly from a terminal instead of wrapping it up into a user function, i.e. why can't I write:
>drive ss2vg 10
instead of always having to write:
>sendmymessage("drive ss2vg 10")
The following code snippet implements a really simple terminal window. In this you type commands into the notebook window, on pressing return the commands are executed. If you wanted to make this act as a terminal for a device instead of the Execute/z/q line you could substitute the code that deals with your device, i.e. sendmymessage(S_Selection). All you have to do then is intercept the incoming messages and display them in the notebook. I leave that as an exercise for the reader (which is what people always say when they don't want to deal with that).
Menu "Macros"
    "Terminal Window/2", TerminalWIndow()
Function TerminalCmdHook(s)
    STRUCT WMWinHookStruct &s
    Variable statusCode = 0
    String platform= UpperStr(igorinfo(2))
    string cmdChar, temp
    if(stringmatch(platform,"MACINTOSH"))
        cmdChar = num2char(-91)
        cmdChar = num2char(-107)
    strswitch(s.winname)
        case "Terminal#TerminalNB":
            switch(s.eventCode)
                case 11: // Keyboard
                    switch (s.keycode)
                        case 30:
                            notebook $s.winname, findtext={cmdChar, 2^4+2^0}
                            notebook $s.winname, selection={startOfParagraph, endOfParagraph}
                            statuscode=1
                            break
                        case 31:
                            notebook $s.winname, findtext={cmdChar, 2^0}
                            statuscode=1
                            break
                        case 13:
                            notebook $s.winname, textRGB=(0, 0,  65535), fstyle=1, fsize=8
                            getselection notebook, $s.winname, 2
                            execute/q/z S_Selection
                            if(strlen(S_Selection) > 0 && (!stringmatch(S_Selection, "\r")) )
                                temp = ""
                                notebook $s.winname, selection={startofparagraph, endofparagraph}
                                if(!Stringmatch(S_Selection[0], cmdchar))
                                    temp = cmdChar
                                temp += S_Selection
                                if(!Stringmatch(S_Selection[strlen(S_Selection)-1],"\r"))
                                    temp +="\r"
                                notebook $s.winname, text = temp
//                          if(strlen(S_Selection)>0)
//                              notebookaction/w=$s.winname commands=S_Selection, frame=1,ignoreerrors=1, title=S_Selection
//                          endif
                            notebook $s.winname, selection={endofparagraph,startofnextparagraph}
                            notebook $s.winname, textRGB=(0, 0, 0)
                            statuscode=1
                            break
                    endswitch
            endswitch
            break
    endswitch
    return statusCode
    // 0 if nothing done, else 1
Function TerminalWindow()
    DoWindow/F Terminal
    if (V_flag != 0)
        return -1
    NewPanel /W=(68, 50, 360, 500) /K=1 /N=Terminal
    SetWindow kwTopWin, hook(Hook1)=TerminalCmdHook
    NewNotebook /F=1 /N=TerminalNB/W=(10, 27, 290, 490) /HOST=#
    Notebook kwTopWin, defaultTab=20, statusWidth=0, autoSave=1, showRuler=0, rulerUnits=1
    SetActiveSubwindow ##
I like this, I learned a lot about using the Notebook commands. Suggestion for the commented-out section:
if( strlen(S_Selection) > 0 && s.eventMod & 2 ) // restrict to the case where Shift was pressed
   temp = S_Selection[1,strlen(S_Selection)-2]  // remove cmdChar and trailing "\r"
   notebookaction/w=$s.winname commands=temp, frame=1, ignoreerrors=1, title=temp
   notebook $s.winname, text = "\r"  // add new line character
Wolfgang Harneit
