ConvertSignedInt64ToDouble
// ConvertSignedInt64ToDouble(highWord, lowWord) // NOTE: This routine has not been thoroughly tested. // Converts a signed 64-bit integer expressed as two 32-bit words into a double. // The two 32-bit words are typically read into Igor using FBinRead/F=3/U. // Double-precision floating point can represent integer values up to 2^53 precisely. // Above that integers are only approximated. Therefore this routine supports // values up to +/- 2^53 and returns NaN for values that are too big. // Examples: // Print ConvertInt64ToDouble(0x00000000, 0x00000001) // Plus 1 // Print ConvertInt64ToDouble(0xFFFFFFFF, 0xFFFFFFFE) // Minus 1 in 2's complement Function ConvertInt64ToDouble(highWord, lowWord) Variable highWord, lowWord Variable result if ((highWord & 0x80000000) == 0) // Positive number if ((highWord & 0xFFE0000) != 0) // Check high order 11 bits result = NaN else result = lowWord + 2^32*highWord endif else // Negative number stored as 2's complement // Theoretically the conversion would be: // result = 2^64 - lowWord + 2^32*highWord // result = -result // However Igor calculations are done in double-precision floating point // and the largest integer that it can represent precisely is 2^53. Thus // we have to discard some of the high order bits to get the signed value // into a range were we can do the conversion precisely. if ((highWord & 0xFFE0000) != 0xFFE0000) // Check high order 11 bits result = NaN else highWord = highWord & 0x001FFFFF // Zap 11 most significant bits result = lowWord + 2^32*highWord result = 2^53 - result result = - result endif endif return result End
