Cluster a correlation matrix
RGerkin
// Create a correlation matrix from fake data, in this case with 2 embedded patterns and // relative noise of 0.25. FakeCorrelationMatrix(2,0.25) // Cluster the correlation matrix with 2 expected patterns. // Picks starting cluster guesses randomly and for high values of noise it might give a poor // result. The /SEED=(ticks) flag makes it give random initial guesses on each run. CorrelationClustering(2,Fake_Corr_Matrix) // Display the data with cluster assignment, the original correlation matrix, and the clustered correlation matrix. Graph0(); Graph1(); Graph2() // Create fake data and a correlation matrix from it. Function FakeCorrelationMatrix(num_patterns,relative_noise) Variable num_patterns // The number of patterns in the fake data. Variable relative_noise // The standard deviation of the noise relative to the signal. Variable length=50 // Each pattern should have this length. Variable num_signals=30 // The number of cells/channels/signals in the fake data. Make /o/n=(length,num_patterns) Base_Patterns=gnoise(1) // Make a bunch of canonical patterns. Make /o/n=(length,num_signals) Data // The matrix of fake data. Make /o/n=(length,num_signals) Waterfall_Colors=q // Colors for the waterfall plot. Make /o/n=(num_signals) Pattern_Values=floor(abs(enoise(num_patterns))) // The true pattern identities, chosen as an integer 0 to num_patterns-1. Variable i for(i=0;i<num_signals;i+=1) Data[][i]=Base_Patterns[p][Pattern_Values[i]] // Each row will be a different pattern. Data+=gnoise(relative_noise) // Add noise to everything. endfor MatrixOp /O Fake_Corr_Matrix=syncCorrelation(Data) // Compute the covariance matrix. MatrixOp /O Variances=varcols(Data) Fake_Corr_Matrix/=sqrt(Variances[p]*Variances[q]) // Convert to degree of correlation. KillWaves /Z Base_Patterns,Variances // Cleanup. End // Cluster a correlation matrix by swapping rows (and columns). Function CorrelationClustering(num_patterns,Corr_Matrix) Variable num_patterns // Number of patterns that you expect to find. Wave Corr_Matrix // The correlation (or covariance) matrix. KMeans /INIT=1 /NCLS=(num_patterns) /OUT=2 /SEED=(ticks) Corr_Matrix // K-Means clustering. Duplicate /o Corr_Matrix Clustered_Matrix // Prepared the clustered correlation matrix. Duplicate /o W_KMMembers Sorting_Index; Sorting_Index=p Sort W_KMMembers,Sorting_Index // Create a sorting index to use to swap out rows (and columns). Clustered_Matrix=Corr_Matrix[Sorting_Index[p]][Sorting_Index[q]] // Shuffle rows (and columns). Wave /Z Waterfall_Colors if(WaveExists(Waterfall_Colors)) Wave W_KMMembers // The pattern number that each signal most represents (the K-Means clustering result). Waterfall_Colors=W_KMMembers[q] // Color the waterfall plot according to the clustering result. endif KillWaves /Z M_KMClasses,W_KMMembers // Cleanup. End Window Graph0() : Graph PauseUpdate; Silent 1 // building window... Display /W=(509.25,50,924,358.25) as "Raw Correlation Matrix" AppendImage/T Fake_Corr_Matrix ModifyImage Fake_Corr_Matrix ctab= {-1,*,RedWhiteBlue,0} ModifyGraph margin(left)=14,margin(bottom)=14,margin(top)=14,margin(right)=14 ModifyGraph mirror=2 ModifyGraph nticks=4 ModifyGraph minor=1 ModifyGraph fSize=9 ModifyGraph standoff=0 ModifyGraph tkLblRot(left)=90 ModifyGraph btLen=3 ModifyGraph tlOffset=-2 SetAxis/A/R left EndMacro Window Graph1() : Graph PauseUpdate; Silent 1 // building window... Display /W=(2.25,386.75,438.75,743.75) as "Clustered Correlation Matrix" AppendImage/T Clustered_Matrix ModifyImage Clustered_Matrix ctab= {-1,1,RedWhiteBlue,0} ModifyGraph margin(left)=14,margin(bottom)=14,margin(top)=14,margin(right)=14 ModifyGraph mirror=2 ModifyGraph nticks=3 ModifyGraph minor=1 ModifyGraph fSize=9 ModifyGraph standoff=0 ModifyGraph tkLblRot(left)=90 ModifyGraph btLen=3 ModifyGraph tlOffset=-2 SetAxis/A/R left EndMacro Window Graph2() : Graph PauseUpdate; Silent 1 // building window... NewWaterfall /W=(-0.75,47,510.75,362.75)Data as "Data" ModifyWaterfall angle=45, axlen= 0.6, hidden= 0 ModifyGraph negRGB=(0,0,65535) ModifyGraph zColor(Data)={Waterfall_Colors,*,*,Rainbow} EndMacro
July 9, 2009 at 02:11 am - Permalink
