Batch rename selected wave and folder names
It can get very tedious if you have lots of waves or folders where you want to delete or replace the same part of the name manually. Here is a rudimentary script which lets you replace or append a string in the names of all waves/folders which are selected in the Data Browser. A prompt pops up which asks for the part of the name to be replaced. I have two drop-in escape codes 'pre' and 'suf' which just prepends or appends the string inserted in "With this". If you just want to delete parts of the name simply leave "With this" empty. This script has served me very well so far. At some point I hope there will be a full batch renamer in Igor, though.
EDIT: Added support for recursive sub-folder renaming and the option to copy with the new name instead of renaming.
String this
String withthis
Variable overwrite = 0
Prompt this, "Replace this (insert: pre = prepend; suf = append): "
Prompt withthis, "With this: "
Prompt overwrite, "Keep original?", popup "No;Yes, try to copy item;Yes, copy and overwrite;"
DoPrompt "Replace Part of the Name", this, withthis, overwrite
if (V_Flag)
return -1
String name = ""
Make/free/T/N=0 selection
Make/free/N=0 sortorder
Variable index=0
do
name = GetBrowserSelection(index)
if (strlen(name) <= 0)
break
selection[numpnts(selection)] = {name}
sortorder[numpnts(sortorder)] = {ItemsInList(name,":")}
index+=1
while(1)
Sort/R sortorder, selection
String namelist
wfprintf namelist, "%s;", selection
QuickRename(this, namelist, withthis, copy=(overwrite-1))
Function QuickRename(String this, String namelist, String withthis, [Variable copy])
Variable copyItem = 0 // copy: 0 = don't keep original; 1 = try copy but don't overwrite; 2 = copy and overwrite
if(!ParamIsDefault(copy))
copyItem = copy
Variable index
for (index = 0; index < ItemsInList(namelist); index += 1)
String NewName = "", OldName = "", infolder = ""
Variable isWave = 1
String name = StringFromList(index,namelist)
Wave/Z work = $name
if (!WaveExists(work)) // is folder
OldName = ParseFilePath(0, name, ":", 1, 0)
infolder = ParseFilePath(1, name, ":", 1, 0)
isWave = 0
OldName = nameofwave(work)
if (StringMatch(this,"pre") == 1)
NewName = withthis+OldName
elseif (StringMatch(this,"suf") == 1)
NewName = OldName+withthis
NewName = ReplaceString(this,OldName,withthis)
if (isWave)
Wave/Z test = $(SelectString(strlen(infolder),"root:",infolder)+NewName)
if (copyItem == 2)
Duplicate/O $Name, $NewName
elseif (copyItem == 1)
if (WaveExists(test) == 0)
Duplicate $Name, $NewName
Rename $Name, $NewName
NewName = PossiblyQuoteName(ReplaceString("'",NewName,""))
if (copyItem == 2)
DuplicateDataFolder/O=3 $(infolder+OldName), $(infolder+NewName)
DFREF testDir = $(infolder+NewName)
if (DataFolderRefStatus(testDir) == 0)
DuplicateDataFolder $(infolder+OldName), $(infolder+NewName)
KillDataFolder/Z $(infolder+NewName)
RenameDataFolder $(infolder+OldName), $(ReplaceString("'",NewName,""))
There is an alternative to using this function that might work well in many situations.
You would select the data folders you want to rename, then click the Execute Cmd... button in the Data Browser. In the dialog, enter a command such as:
RenameDataFolder %s, %s_suffix
Then make sure the "Execute for each selected item" radio is checked. Then click the OK button.
If you were selecting waves and data folders you would need to call a user defined function to do the renaming since there isn't a built-in operation that can rename both waves and data folders.
November 10, 2020 at 08:33 am - Permalink
Yes, I think the closest thing for waves would be:
Rename %s, $ReplaceString(this,NameOfWave(%s),withthis)
But this lacks robustness, since Rename is not able to overwrite anything. Above code puts both cases + some error handling and minimal GUI in a nice package for convenience. Is there a chance that the official Rename Objects function in Igor is expanded at some point to allow for batch renaming functionality (like search and replace or template rename)?
November 10, 2020 at 11:16 pm - Permalink
I wrote a GUI that is a bit like Igor's Rename window, here. Might be easy to turn it into a batch renamer. It's a bit primitive compared with the built in dialogs, but for simple tasks it can be a starting point.
If there were a fully functional embedded object browser, like the one in the rename dialog, available as a panel control that would make things much easier. Maybe that already exists in Igor 9?
November 11, 2020 at 12:58 am - Permalink
In reply to I wrote a GUI that is a bit… by tony
No, there's nothing like that in IP9 and probably never will be. Controls in panels are completely separate beasts from the things you might call controls (we call them widgets) in dialogs. It would be a truly massive amount of work to add an object browser control that could be used in panels. There is always the possibility of using the modal data browser for these types of situations. It's not perfect, but in some situations it's a lot nicer than using the wave selection package we ship with Igor.
November 11, 2020 at 06:49 am - Permalink
That answer sounds familiar. I suspect it's not the first time I have asked :)
There are pros and cons to both modal data browser and wave selector 'widget' (which i guess is not a widget in the sense above), but between them they usually provide enough options to get the job done.
November 11, 2020 at 07:15 am - Permalink
Tony, your normalize panel has indeed some nice ingredients for programming a batch rename GUI. I will have it on my list for a possible future project when I have more time to spare.
November 11, 2020 at 04:39 pm - Permalink
@chozo: Your code seems to do the job or? The only thing I'm missing is descending into datafolder recursively and having an option to choose between not-overwriting and overwriting.
November 15, 2020 at 07:16 am - Permalink
Hi Thomas, yes the code is doing the most simple tasks just fine. What would be nice, however, is a feature rich batch rename tool with something like multiple replacements in one go, a nice template generator to rename things with info from the wave notes or wave info and numbers / dates or even reshuffling of name parts. This would take a lot of time to put together but is in principle easy to do.
You are right that non-overwriting and recursive renaming would be an useful addition. I will look into that.
November 17, 2020 at 02:46 am - Permalink
OK, I have updated the snipped now (see first post). I didn't do exhaustive testing, so please let me know if there is something wrong.
November 18, 2020 at 07:53 am - Permalink
@chozo
something for you to test:
[edit: see below for updated version]
November 18, 2020 at 09:31 am - Permalink
Tony,
Wow, so you have already put together a first GUI. I had a quick look at it. Do you want to open your own snippet or project page or should we discuss here? I found a few glitches, but I did not look at the code long enough to understand every part yet.
November 18, 2020 at 11:01 pm - Permalink
here is a github repository if you want to edit.
i reused a lot of code from other projects, and i really haven't tested at all.
November 19, 2020 at 12:29 am - Permalink
Thanks! I am currently completely overloaded with work, but may hack away at it when I get the time to code again.
November 20, 2020 at 04:31 pm - Permalink
I've been using the GUI a bit and it has proved useful. Maybe I'll release it as a project. Here is the most recent version, if you want to take a look.
EDIT
stuck it on here as a project: https://www.wavemetrics.com/node/21571
It renames things, but doesn't do any of the other useful things suggested in this thread.
February 19, 2021 at 02:41 am - Permalink
