Auto-start when procedure file is compiled
Here's a trick to start up some code when the procedures are compiled (so the user doesn't have to choose any menu or run a command).
Use a dynamic Menu definition to do two things:
1) Return the menu item string, as per normal.
2) Schedule the starting-up code with Execute/P.
Here's a demo. Copy and paste into the Procedure window and somehow cause compilation to occur (by, say, simply closing the Procedure window):
Menu "Macros", dynamic
    AutoStartMenu(),/Q,DoNormalStuff()
Function/S AutoStartMenu()
    // Test if auto start is needed
    NVAR/Z haveStarted= root:gHaveStarted
    if( !NVAR_Exists(haveStarted) )
        Variable/G root:gHaveStarted=1 // do this now to prevent double scheduling
        Execute/P/Q/Z "StartUp()"
    return "Do Normal Stuff"
Function StartUp()
    DoAlert 0, "Starting Up"
To make the StartUp function run every time procedures are compiled or re-compiled, modify it as so ...
Function StartUp()
       killvariables/Z root:gHaveStarted   // killing variable here causes next compile to rerun this function
