Add 'Invert Wave' to graph contextual menu
Menu "TracePopup" "-" // separator divides this from built-in menu items "Invert wave", /Q, InvertWave() End //** // Invert the wave that the user selected. Note that this inverts the wave itself // and not just the trace. //* Function InvertWave() GetLastUserMenuInfo // determine the wave name based on the trace name and window name WAVE targetWave = TraceNameToWaveRef(S_graphName, S_traceName) targetWave *= -1 End
You can just copy and paste this code into a procedure file and compile. If you want this behavior to occur from any experiment whenever you start Igor Pro, you'll need to create a stand alone procedure file containing this code and put a shortcut/alias to that procedure file in your
Igor Procedures
directory.
