This example covers four tests that are available in the StatsCircularTwoSampleTest operation. All tests are used to compare two samples of circular data which represent either raw data or means of data (second order analysis).
For the first two examples we use the waves Sample1, Sample2 and Sample3:
Sample1
Angle Radius
2.07109 1.05535
2.20479 1.11541
1.6637 1.12639
2.14861 1.01445
2.3785 0.990459
2.0421 0.985494
2.14861 1.02701
1.98404 0.944105
1.87446 0.986208
1.97171 0.888526
1.81322 0.976384
Sample2
Angle Radius
2.09745 0.925728
1.86866 1.03347
1.95995 1.00445
2.01705 0.932245
2.04559 1.06179
2.04506 0.999727
2.42668 1.0344
2.03605 1.0751
2.33602 1.0398
2.18839 0.935943
1.92262 1.03721
Sample3
Angle Radius
1.81504 0.925728
1.93231 1.03347
1.84001 1.00445
1.8353 0.932245
1.85639 1.06179
1.81432 0.999727
1.93607 1.0344
1.89947 1.0751
1.57929 1.0398
1.84727 0.935943
1.86696 1.03721
Non-Parametric Paired-Sample Test
To test if the pairs represented by corresponding rows in Sample1 and Sample2 are the same (H0) execute the command:
StatsCircularTwoSampleTest/Q/T=1/NPR Sample1,Sample2
The results of the test are summarized in the table:
numPairs 11
Rp 0.350962
Critical 1.04402
P-Value 0.739203
Since the statistic Rp is smaller than the critical value we can't reject H0 that the two paired distributions are the same.
StatsCircularTwoSampleTest/Q/T=1/PPR Sample1,Sample2
numPairs 11
xBar -0.0520224
yBar -0.0247836
F 0.246806
Critical 4.25649
P-Value 0.786411
As expected the parametric test results in the same conclusion that H0 can't be rejected. To repeat the test and compare Sample1 to Sample3 execute the command:
StatsCircularTwoSampleTest/Q/T=1/PPR Sample1,Sample3
numPairs 11
xBar 0.170992
yBar 0.0770423
F 4.62463
Critical 4.25649
P-Value 0.0415419
In this case the pair-wise equality of the samples is rejected.
Two-Sample Parametric Second Order Test
Suppose you have two samples of means of circular data contained in Sample4 and Sample5 as shown below.
Sample4
Angle Radius
1.95156 0.998453
2.02499 0.966636
1.923 0.900775
1.93213 0.952201
2.11902 0.980929
1.90744 0.993908
2.09811 0.999118
2.03358 0.901898
Sample5
Angle Radius
1.86072 0.994223
1.74222 0.930861
1.98412 0.90284
1.66055 1.0654
1.94668 1.00991
2.03487 1.02034
1.83005 0.957592
1.79043 0.956647
1.68544 0.973875
1.62441 0.944371
2.05969 1.02666
To test if the means of the populations from which the two samples were taken are equal (H0), execute the following command:
StatsCircularTwoSampleTest/Q/T=1/PSOA Sample4,Sample5
Samples1 8
xBar1 -0.398434
yBar1 0.872187
r1 0.958885
a1 1.99931
Samples2 11
xBar2 -0.25697
yBar2 0.935076
r2 0.969743
a2 1.83899
F 4.03807
Critical 3.63372
P-Value 0.0380423
Since the F statistic is greater than the critical value we reject H0.
Two-Sample Non-Parametric Second Order Test
To test the same data using a non-parametric test, execute the command:
StatsCircularTwoSampleTest/Q/T=1/NSOA Sample4,Sample5
Total_Points 19
Watson_U2 0.202153
Critical_Tiku 0.184557
Approx_P 0.0345285
Critical 0.184103
Clearly the Watson_U2 statistic is greater than the critical value and H0 (equality of the means) must be rejected.
