Main navigation
Products
Igor Pro
Igor Pro 10 Highlights
New Features 10
New Features
How to update
Previous versions
Igor Pro 9 Highlights
Igor Pro 9 Changed and New Features
Igor Pro 8 Highlights
Igor Pro 8 Changed and New Features
Igor Pro 7 Changed and New Features
Igor 6.3 reasons to upgrade
Igor 6.3 new features
Igor 6.3 changes since release
Igor 6.2 new features
Igor 6.2 changes since release
Igor 6.1 new features
Igor 6.1 changes since release
Igor 6 New Features
Igor 6 Release Notes
Unique Hybrid Interface
Data Access
File Formats
Binary Files
HDF5
Hardware Data Acquisition
Micro-Manager
Export Formats
Internet Support
SQL Databases
External Access
Data Storage
Data Folders
Creating Graphics
2D graphs
XY plots
New graph details
Trace settings
Axis settings
Category Plots
Contour Plots
Flexible axes
Animations
Preferences and templates
Page Layouts
Tables
Drawing tools
Annotations
Color Tables
Subwindows
3D and Volume
Surface Plots
Path and Ribbon Plots
3D Scatter
3D Object Plots
Isosurfaces
Voxelgrams
Volume Slices
3D Animations
Exporting Graphics
Image Processing
Image Acquisition
ROI
Image Transforms
Mathematical Operations
Histogram Modifications
Image Interpolation
Image Registration
Background Removal
Image Rotation
Color Spaces
Thresholding
Localized Filters
Edge Detectors
Morphology
Image Analysis
Image Statistics
Line Profile
Particle Analysis
Image Snake
Data Analysis
Curve Fitting
Built-in types
User-defined
Constraints
Errors in Variables
Global Fitting
Multidimensional
Peak Analysis
Peak finding
Baseline removal
Multi-peak fitting
Signal Processing
Fourier transforms
Spectral windowing
Power spectra
Hilbert transforms
Time frequency analysis
Digital filters
Smoothing
Convolution and Correlation
Level detection
Statistics
Statistical Tests
Angular Distribution Tests
ANOVA1 Tests
ANOVA2(NR) Tests
ANOVA2(RM) Tests
Chi-Squared Tests
Angular-Correlation Tests
Circular Means Tests
Circular Moment Tests
Circular Two Sample Tests
Cochran Test
Dunnett Test
Friedman Test
F Test
Hodges-Ajne Test
Jarque-Bera Simulation
Kendall's Tau
Kolmogorov-Smirnov Test
Kruskal-Wallis Test
Linear Correlation
Linear Regression
Multi-Correlations
NP Multi-Comparison
Nominal Serial Randomness
Spearman Rank Correlation
Bootstrap and Jacknife
Scheffe's Test
Serial Randomeness
T-Test Examples
Tukey Text Examples
Variances Test Examples
Watson's U2 Test
Watson-Williams Test
Wheeler-Watson Test
Wilcoxon Tests
Weighted Rank Correlation
Noise Functions
Probability Distribution Functions
Cumulative Distribution Functions
Inverse CDFs
General Purpose
Procedures and Packages
Computational Geometry
Data Manipulation and Math
Mathematical Functions
Matrix and Linear Algebra
Analysis of Functions
Plotting
Optimization
Root finding
Integration
Ordinary differential equations (ODEs)
Igor Filter Design Laboratory
Data Exploration
Programming
Python Integration
External or Internal procedures
Code Editor
Contextual help
Packages
Debugger
Custom Interfaces
Controls and control panels
Control types
Custom menus
Notebooks
On-line Help
Video Tutorials
Platform Support
NIDAQ Tools MX
Details
Applications
Supported Hardware
Requirements
XOP Toolkit
Versions
Manual
Example XOP
Development Systems
Third Party
Data Acquistion
Cameras/Digitizers
Instruments using IGOR
Software
Developers and Consultants
Resellers
OEM Information
News & Blog
Downloads
All Downloads
Current Releases
Samples Galleries
Case Studies
Space Physics Research
Atmospheric Research
MFP3D Atomic Force Microscope
Neuromatic and NClamp
NeutroNM
Neutron Scattering
TGSGUI Optical Simulation
Wide-Angle Neutron Spin Echo Spectroscopy
ZeFir
IgorExchange Forums
All Recent Activity
General (Main) Forum
Igor Pro Wishlist Forum
News and Announcements Forum
WaveMetrics.com Forum
Code Snippets
Projects
Join the Forum (Register)
Support Center
Documentation
Contact Us
FAQ
Video Tutorials
Current and Legacy Versions
User Resources & Contributions
日本語サイト / Japanese
Igor Pro® 10 ハイライト
Igor Pro® 10 の新機能の解説
Igor Pro® 10 システム要件
Igor Pro 概要
ユニークなハイブリッドインターフェイス
データアクセス
データのインポート
バイナリデータ
HDF5 サポート
ハードウェアからのデータ取得
Micro-Manager
グラフィックスの作成
2Dグラフ
XY プロット
カテゴリプロット
コンタープロット
柔軟な軸
アニメーション
プレファレンス
サブウィンドウ
ページレイアウト
テーブル
描画ツール
注釈
カラーテーブル
3Dとボリューム
サーフェスプロット
パスプロットとリボンプロット
3D 散布図
3D オブジェクトプロット
等値面プロット
ボクセルグラム
ボリュームのスライス
グラフのエクスポート
画像処理
画像の取り込み
ROI(関心領域)
画像変換
カラースペース変換
画像の閾値
輪郭検出
画像解析
画像の統計
ラインプロファイル
粒子解析
画像のスネーク(輪郭)
データ分析
カーブフィッテイング
組み込み
ユーザー定義
制約付き
変数誤差
グルーバルフィッティング
多次元
ピーク分析
ピーク検出
ベースライン除去
マルチピークフィッティング
信号処理
フーリエ変換
スペクトルウインドウ処理
パワースペクトル
ヒルベルト変換
時間周波数解析
デジタルフィルタリング
平滑化
畳み込みと相関
レベル検出
統計分析
統計的検定操作
ノイズ関数
確率分布関数
累積分布関数
逆累積分布関数
汎用のコマンドと関数
プロシージャとパッケージ
計算幾何学
データの操作と計算
数学的関数
行列計算
関数の分析
プロット
最適化
根を見つける
積分
ODE の数値解法
プログラミング
Python との統合
外部・内部プロシージャ
コードエディター
コンテキストヘルプ
パッケージ
デバッガー
カスタムのインターフェイス
コントロール
コントロールの形式
カスタムのメニュー
IFDL - Igor Filter Design Laboratory バージョン 4
ノートブック
日本からのご購入について
コースワークライセンス
ガイドツアー(日本語特別版)
ヘルプ(日本語ビジュアル版)
各種日本語サポート情報
User account menu
Forum Log In
Create a Forum Topic by Logging In or Creating an Account
Radar or Spider plot
mtaylor
Mon, 09/10/2012 - 09:54 am
Does anyone know of an easy way to produce a category star, radar or spider plot (same plot, different names)? I have searched the igor help files and it doesn't seem to be built in.
http://en.wikipedia.org/wiki/Radar_chart
I can of course program a polar graph to do this, but I would prefer an easier solution if it exists or is built in.
