First: I am sorry to say this, but you should make it a habit to explain yourself, i.e., what you actually want to do, what you have tried and what did not work. Stating the OS and Igor version is often useful as well. For example, why do you have 3 y and z waves? Do you want to make 3 plots or somehow merge them? Also, Gizmo plot come in a wide variety of types (Surface, Bar, Scatter etc ...). Which one do you want?
Anyway, I assume you want to plot one data set XYZ, so it is most useful to merge, e.g., wave0/1/2 into one XYZ triplet matrix. With that I plotted the data as both scatter and surface representations in the attached file. Is that what you wanted to do?
August 1, 2023 at 09:55 pm - Permalink
Thank you that's what I needed to know about the merge plot.
Next time I will try to be more explicit.
August 1, 2023 at 11:08 pm - Permalink
